AmazonBasics HDMI Cables?
AsSiMiLaTeD
Anyone tried the HDMI cables from AmazonBasics?
I've always been a fan of the Monoprice stuff, but I've had a couple of their cables fail on me and the last few I've bought from them are VERY thick and hard to work with. The cables from Amazon look thinner and seem to have good reviews, but don't give specifics about what version they are or anything like that. Here is the one I'm looking at:
http://www.amazon.com/AmazonBasics-High-Speed-Supports-Ethernet-Standard/dp/B0052SCU8U/ref=cm_cr_pr_product_top
I suppose for $10 it's not a huge risk,but thought I'd ask anyway.
Post edited by AsSiMiLaTeD on
I went through 3 and they break inside and have a little noise on 25 ft. The connectors seem to break inside the wire at the connection but I was always rotating them around but still
I have ones like Rick88. No issues, but I'm not a videophile, nor do I move cables around with any type of frequency.
Are you buying the 22, 24 or 26 gauge cables from Monoprice? Those will be stiff, but that's also a thicker gauge of wire than you will find in most HDMI cables. They do have standard 28 gauge cables, and now they also have 36 gauge cables with Redmere.
http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10255
Haven't tried the AmazonBasics stuff but I see no reason not to.
Monster AVL-300, HTS-2500 MKII -
I dont but based upon the reviews I would give them a trySpeakers: SDA-1C (most all the goodies)
For ten bucks you cant go wrong.
Dan
polkfarmboy wrote: »I went through 3 and they break inside and have a little noise on 25 ft. The connectors seem to break inside the wire at the connection but I was always rotating them around but still
Well.....ya ain't supposed to stick 'em into the binding post! :eek:--Gary--
Most items with hdmi ports are high ticket items so why pay all that money just to hook them up with a $10 cord?
Dear lord not again.
No offense, but everything you touch seems to break.:cheesygrin:The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Popcorn Ready!
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
I just wanted to report back that I've been using these for a couple weeks now and they work great. I like the fact that they're very flexible and easy to work with, and produce an excellent picture.
Good to know! Might use them next time I need cables, since Monoprice doesn't have free shipping. I'm always buying stuff from Amazon, so it'd be easy to hit the $25 free-shipping mark.
Monoprice sells many products on Amazon with free supersaver shipping also.2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0 -
What?? Well sonofa...
