Goodbye Binding Post Cup. 1.2tl's
13
    EndersShadow Posts: 17,719
    edited November 2012
    vmaxer wrote: »
    How can I get these??
    There was a member named Musky who did some of these as one off's for the forum. I don't believe he is making anymore of them, but feel free to contact him and see.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    I decided to take a cue from Roger Russell and rewire my SDA SRS 1.2TL's with Cardas copper Litz wire in 15.5 gauge. The Cardas wire is slightly larger than the stock wire, which is 16 gauge. This is the same wire that Mr. Russell uses in his $18,000 IDS-25 loudspeaker system. However, Mr. Russell does not believe the Cardas wire offers any sonic advantage over ordinary wire. He just uses it for marketing reasons. [Link: Cardas wire and the IDS-25]
    There is nothing wrong with the stock wire. I just want to see if the better wire makes a difference in this application. The Cardas wire is a lower noise design due to the Litz configuration (reduction of strand interaction by insulating individual wire strands) and due to the polished surface of the conductors. AudioQuest uses similar technologies in their cables.
    The wire will be conditioned on the Audiodharma Cable Cooker prior to assembly.
    Figure 1. Main ingredients: wire and connectors.
    Figure2. I will be using 1/4" WBT quick disconnects, which are gold plated copper.
    Figure 3. I found that I could use the WBT disconnects with the narrow tab on the RD0198 tweeters if I gently pry up the middle band on the back of the disconnect and slide the tweeter tab under it.
  • headrott
    headrott Posts: 5,496
    Looking forward to the results Raife. Cardas Litz wire is very good sounding stuff, IMO. I used it in the DAC I made.
  • nspindel
    nspindel Posts: 5,343
    Oh say it ain't so! The one piece of my speakers that I haven't modded is the wiring harnesses. I have a feeling that you're going to come back and say "WOW!!!!!"
  • drumminman
    drumminman Posts: 3,396
    Interesting - I'm a believer in a Litz type configuration. Multiple smaller wires individually insulated and braided.
    I use a diy version in my speaker cables: teflon insulated 24 awg solid core copper, 27 pairs braided on the lows (equivalent to 9 awg), 9 pairs braided on the highs (15 awg). The benefits are supposed to be reduced skin effect, reduced smearing from strand jumping of the signal, very low inductance.
    Looking forward to your report.
    Toolfan66 Posts: 18,164
    Great!! I have been wanting to do this for some time now, I'm looking forward to your findings..
  • DarqueKnight
    headrott wrote: »
    Even if this doesn't work, I can sleep better knowing that my speakers are full of audiophile approved Cardas wire.:razz:
  • nspindel
    Too bad it doesn't come in colors other than black and red. Would be good to be able to stick with spec colors. Could always throw a bit of colored shrink tube on the end to indicate white, blue, green, etc., but would look better if the jacket was the correct color....
  • agfrost
    agfrost Posts: 2,474
    You and Roger are like two peas in a pod, Raife.
    Jay
    F1nut Posts: 51,956
    Cardas wire is a PITA unless you've got a solder pot.
    It use to come in lots of colors, might have to look around a bit tho.
  • headrott
    Or even better Raife, the fact that it's used by Roger Russel!:wink::eek::razz:
  • headrott
    I didn't find it too bad Jesse. I just used my Weller soldering iron. It does take a little patience, but not too bad IMO.
    It really depends on the gauge you are looking for how easy it is to find multiple colors. At 15.5 AWG it may be more difficult. I found smaller gagues in Red, Green, Blue, White, and Black at Sonic Craft a couple years back. All these colors are probably made in 15.5 AWG but as you said Jesse are much harder to find.
    pitdogg2 Posts: 27,244
    I get the feeling you sleep like a baby anyway:cool:
    curious to know what you do to the enamel coating on his wire to make your crimp work better or are you tinning the wire before hand?
  • DarqueKnight
    The limited colors didn't bother me as I prefer the conventional colors of red for + and black for -. I am going to color code the ends with acrylic paint according to driver/tweeter number.
    ...curious to know what you do to the enamel coating on his wire to make your crimp work better or are you tinning the wire before hand?
    I am using a Dremel with a stainless steel wire wheel (attachment #503) to grind off the annoyingly clear and invisible polyurethane coating. Continuity is confirmed with a multimeter. The wire is rotated 90 degrees and secured in four different orientations so that all sides of a strand get treated.
    I am using all crimped connections as they are electrically quieter than soldered connections. All of the grinding and crimping is a tedious process, but I am hoping there will be some audible benefit from the cleaner connections and reduced strand interaction.
    I do.:biggrin:
    could someone use some sort of liquid stripper? would it just be more gunk in the way? I was just thinking one could strip and wash for good clean metal without all the tedious dremal work on such small areas. I've always liked Cardas items and had very good luck, but the wire i must say been very hesitant about because of what others have told me that used it.
  • gimpod
    gimpod Posts: 1,793
    Ray, Just a thought why not use colored heat shrink tubing, it won't come off and you can use it on the connector barrel to help seal the connection.
    I didn't know that, I guess you do learn something everyday. :cool: I was taught that crimping was done for a good mechanical connection and then soldered for a good electrical connection.
    Anyway I'll be very interested in your results as I've still got my 4.1TL project to finish that I have to make up a new wiring loom for and a new set of 1C's to do.
  • nspindel
    Only thinner gauges. 15.5 is only red and black, at least at soniccraft.
  • DarqueKnight
    I don't know of any solvent that will dissolve cured polyurethane. If there were such a solvent, cleaning the resulting sticky gunk would be another problem. It seems that, with polyurethane, we are stuck with burning it off with solder or grinding it off.
    I just wish the wire coating was colored so that I could visually tell when it was all off!
    gimpod wrote: »
    Painting is quicker and easier.
    gimpod wrote: »
    Solder is quick, easy, and convenient, but the metals used are not as conductive as copper...hence the use of silver to improve conductivity. The best electrical connection is a metal-to-metal pressure weld, but this is impractical in many situations.
  • drumminman
    How about setting up an oil lamp, removing the glass chimney and burning it off over the flame? Should be easy to control.
  • DarqueKnight
    I meant to say attachment #530. However, I have replaced attachment #530 (stainless steel brush) with attachment #428 (carbon steel brush). The carbon steel brush works faster and is more appropriate for this type of work. From the Dremel product descriptrions:
    428-Carbon Steel Brush - "Remove dirt, rust, and corrosion from most surfaces. Clean electrical connectors and other metal parts, remove buildup from faucets, clean camp stove burners and more."
    530-Stainless Stee Brush - "Use on stainless steel, pewter, aluminum, silver and other white metals. Use for cleaning, deburring and surface finishing."
    The carbon steel brush is attached to the Dremel. The stainless steel brush is at the lower left. The work
    surface is the bottom of an aluminum baking pan.
    drumminman wrote: »
    I don't see any smiley's, so I am assuming you are not being facetious. The hair-thin wires easily get red hot and incinerate in an open flame. Even if incineration weren't a problem, you would still have to scrape off the charred polyurethane residue...and soot from the oil.
  • drumminman
    Nope, no smiley faces. I was serious. Good points though. I suppose I was thinking solid core, burn it off and make a couple passes with some 0000 steel wool to remove the residue.
    OK, carry on :lol:
    edited January 2013
    Lasered the plates today. Machine the delrin next week. After seeing Jesse's dreadnought with the NL2's I had to change it. Guess I should have listened to Mike in the first place.. :cheesygrin:
    F1nut Posts: 51,956
    edited January 2013
    I used the NLT4's, a bit beefer all around.
  • audio_alan
    audio_alan Posts: 770
    edited January 2013
    Great work, as always Larry! Speakon connections are great. No chance of them accidently coming off...
    edited January 2013
    I just saw that. humm wonder if I should order a set before I machine the delrin? I am going to counter bore it so it sets flush to it, and put the stainless flush as you see it..
  • DarqueKnight
    edited January 2013
    Toolfan66 wrote: »
    I would suggest a right angle connector, like the Speakon NL4FRX, at the speaker for better strain relief. This would also provide more flexibility in moving the speakers closer to the wall if needed. I don't know if the NL4FRX would provide enough clearance above the top binding posts though.
    edited January 2013
    I could change it and put it on the bottom..:cheesygrin:
    F1nut Posts: 51,956
    edited January 2013
    I've got no issues with strain relief or clearance to the wall. My speakers are 6" off the back wall and there's room to spare.
  • schwarcw
    schwarcw Posts: 7,358
    edited January 2013
    I like this idea! There is room for the big MIT S1 cables, however but a right angle connector would be a nice option.
    Carl
    F1nut Posts: 51,956
    edited January 2013
    I see an issue with the NL4FRX if one is using MIT Shotgun cable. The maximum inside diameter of the shell at the tail end is 14.5mm. The one I used had a maximum inside diameter of 16mm and I had to enlarge it to 21mm, which was at the absolute edge of what it could be enlarged to. The shell also appears to be shorter than the one I used, which may also present an issue.
