Found The Pin Blade Connector Online
PolkieMan
PolkieMan Posts: 2,446
edited December 2012 in DIY, Mods & Tweaks
I think this is it. You guys please correct me if I am wrong.
http://www.mcmelectronics.com/product/DISTRIBUTED-BY-MCM-13HP035B-/CN00767
Post edited by PolkieMan on
  • Conradicles
    Conradicles Posts: 6,396
    edited November 2012
    Not sure but it looks like one. You are aware the blade does nothing and all you need is the pin? A high quality RCA cable modified works great.
  • PolkieMan
    Yes that is what I am using now but in would be nice to make one like the original and of course get the extra support. I just thought these were unavailable anywhere till today. Shipping is too much though.
    Toolfan66 Posts: 18,292
    Keeping these speakers original is overrated anyways. When there are much better options with connectors and cables to be used..
    Get your modding on I say!!:lol:
    VR3 Posts: 29,630
    NL2 is where it is at!
    F1nut Posts: 52,157
    PolkieMan wrote: »
    That's a DIN connector, it will not work on SDA's.
    The company that made the originals was bought out years ago and that company does not make the pin/blade connectors.
  • PolkieMan
    Thanks for the reply!
    I will probably go the binding post route since the original is gone forever.
  • Systems
    Systems Posts: 14,872
    Cinch still makes the right pin/blade connector.
    They also make the right blade/blade.
    That said, you are WAY better off going binding posts.
    Just being able to use any speaker cable you like would pay off enough for
    the investment.
    Most all of the Pin and Blade connectors are nickle plated anyway.
    WOULD not be beneficial for SQ in the least.
    Testing
    Testing
    Testing
    F1nut Posts: 52,157
    Got a link for that?
    Gotta disagree, Neutrik is the way to go.
