Found The Pin Blade Connector Online
PolkieMan
I think this is it. You guys please correct me if I am wrong.
http://www.mcmelectronics.com/product/DISTRIBUTED-BY-MCM-13HP035B-/CN00767
Not sure but it looks like one. You are aware the blade does nothing and all you need is the pin? A high quality RCA cable modified works great.
Yes that is what I am using now but in would be nice to make one like the original and of course get the extra support. I just thought these were unavailable anywhere till today. Shipping is too much though.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
NL2 is where it is at!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
That's a DIN connector, it will not work on SDA's.
The company that made the originals was bought out years ago and that company does not make the pin/blade connectors. -
Thanks for the reply!
I will probably go the binding post route since the original is gone forever.That's a DIN connector, it will not work on SDA's.
The company that made the originals was bought out years ago and that company does not make the pin/blade connectors.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
Cinch still makes the right pin/blade connector.
They also make the right blade/blade.
That said, you are WAY better off going binding posts.
Just being able to use any speaker cable you like would pay off enough for
the investment.
Most all of the Pin and Blade connectors are nickle plated anyway.
WOULD not be beneficial for SQ in the least.Testing
Testing
Testing -
Got a link for that?That said, you are WAY better off going binding posts.
Gotta disagree, Neutrik is the way to go.
