carver SD/A 490t?
warlocks1
warlocks1 Posts: 1,284
Someone local is selling this Carver cd player for $200.00 with no remote. Is it worth it? I am currently using a Sony s7700 for my CD's. Will I notice the difference? Thanks, Jeff
Post edited by Ryan_Polk on
  • George Grand
    George Grand Posts: 12,256
    edited May 2004
    Unless it's the tube one, and I don't think it is, save your cash. I have a Carver TL-3300, WITH original box, manual, remote, and packing. $200 is excessive for no remote . It's excessive if it's not the tube one.
    George Grand (of the Jersey Grands)
  • amulford
    amulford Posts: 5,020
    edited May 2004
    I wouldn't give more than $75 - $100 for one.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited May 2004
    Isn't the 't' the tube designation?
  • warlocks1
    edited May 2004
    It is the tube one. Does that make it woth it?
  • RuSsMaN
    edited May 2004
    Offer him a buck and a quarter. Great sounding cdp, you tell me if it's worth it to you.
    I think I've seen em' bring 2-3 bills on the bay.
    Cheers,
    Russ
  • George Grand
    edited May 2004
    I would do the same thing. $125. Screw the remote.
    I was thinking that 19 should have been in the model number for the tube cd player, but I think maybe C-19 was the tube preamp from around 1991 or 92.
