heat from lsi25
I have been noticing that the back of my lsi25 which is the iron grill where the powered sub is located is always hot even if it has been unused for a while. And the left speaker is not getting hot but only the right speaker. Is there something wrong with my right lsi25? This situation has ben a long time in the first place and I don't notice any change in sound quality too. Can you tell me your experience about it?
Hello,
I believe that is caused by the bass amplifier's bias adjustment being too high. You should contact Polk's CS department at 1-800-377-7655 or via email at: polkcs@polkaudio.com on Monday. They'll help you take care of that.
Regards, Ken -
The problem is my speakes is out of warranty cuz it's more than five years now fro the itme I bought them.Kenneth Swauger wrote: »Hello,
Regards, Ken -
Do you think this is what is causing my apms to go to protected mode?
Hello,
It's probably still a good idea to contact Polk, even though you are out of the product warranty period they will take everything into consideration. It's doubtful that the bass amp's bias has anything to do with an external amp going into protection mode. If you reduce the overall playing volume does the amp still shut off? In other words, will the external amp always go into protect mode, or only under certain circumstances?
Regards, Ken -
Regards, Ken
My xpr2 goes into protection mode once a year I guess. But yesterday I was listening to music then after 8 minutes, my amps shut down again. Also, Do you think I can fix the issue on m lsi25 myself just in case? -
Why didn't you get it fixed when the issue first started?My xpr2 goes into protection mode once a year I guess.
Why does that happen, volume too high?Do you think I can fix the issue on m lsi25 myself just in case?
No.Political Correctness'.........defined
President of Club Polk -
I thought it was normal. I never knew till this week that even if I turned off the amp ( not on and not auto ), the amp is still hot unless you unplug the cord.
It's at normal volume. It shut off after 10 mins of listening to music...[/COLOR]
No.
How much do you think it would cost me for a repair or replacement of this amp? -
Another solution is buy another pair of lsi25 and return my cm9 since I notice that there is no much difference in sound quality and I don't know why. I guess my ears are not that smart as others. hat do you think????
Splitting hairs I know, but the XPR-2 isn't out yet. I think you are talking about an XPA-2?
..."The ear is not a microphone, the brain is not a tape recorder, and measurements are limited in describing subjective quality." Nelson Pass
2 Channel:
XDA-2, Modified Jolida JD502P (2 ea), Polk LSiM705
Theater:
Onkyo TX-NR3009 with 9 active channels, Emotiva XPA-5, MartinLogan Encore TF Center Channel, Polk M70 Mains, M40 Wides, M30 Heights, FXi A4 Surrounds, Custom built 18" sub, Mitsu 73" DLP -
That's what I mean, XPA-2, my friend? Thanks for correcting me! I really do appreciate it... -
Here is the status of my lsi25 amplifier. I sent this amp out to San Diego CA. for repair. But after less than two weeks, I received a phone call from the polk audio tech department telling me that they don't fix that amp anymore. Instead, they want me to buy a brand new one which is very expensive and pay for the tax too ( even though I live in florida ) plus the shipping. Isn't that fair? Did this happen to you before???
It's fair if they are out of warranty which sounds like the case here. Either bite the bullet and get a new amp, get new speakers or have the amp returned to you and see if you can source someone to fix it locally. However, since you've gone this far, I'm inclined to suggest buying the replacement amp. -
Do we have anybody in this forum who wants to sell thier lsi25 amp with reasonable price?
How much is the new amp?Political Correctness'.........defined
I was quoted for the price of less than $340 not including the tax and shipping. I dont understand why they need to tax me since I live in florida... -
That seems like a reasonable price to me.
They are required to charge tax in any state they do retail business in.Political Correctness'.........defined
The price of the brand new lsi25 is 650. So I am thinking of buying a new one than buying amp replacement. What do you think?
That's a steeply discounted price, but still almost twice the price for the new amp. You decide.Political Correctness'.........defined
It's a tough decision though.
