ARAGON 2002 THX amplifier info and worth...
Mystery
Mystery Posts: 2,546
edited November 2012 in Electronics
Anyone familiar with this amp?
Also, what would be a good price on these?
http://www.aragonav.com/storage/2002_2.jpg?__SQUARESPACE_CACHEVERSION=1339606877167
Specifications
DESIGN 2-ch THX Ultra2 Amplifier
POWER OUPUT 8 200 watts/ch into 8 ohms at less than 0.03% THD (20Hz-20kHz - both channels driven)
POWER OUTPUT 4 300 watts/ch into 4 ohms at less than 0.05% THD
FREQUENCY RESPONSE 20Hz-20kHz +0/-0.1dB
10Hz-100kHz +0/-0.5dB
TIM/DIM DISTORTION 0.00%
S/N RATIO 106dB A-weighted
DAMPING FACTOR 500 (8 ohms - 50Hz)
INPUT SENSITIVITY 100mV-1W / 1.42V-200W
INPUT IMPEDANCE 20k ohms
POWER CONSUMPTION 60W @ Idle / 1000W Maximum
BUILT FROM 2002
Post edited by Mystery on
  • zingo
    zingo Posts: 11,258
    Probably decent amp, but I wouldn't pay more than $500 for it without a good reason.
  • mantis
    mantis Posts: 17,322
    Excellent amps and I've done full THX Spec'd theaters with them. What's it going for?
    Dan
  • Mystery
    Thanks for comments.
    One of my buddies wants to sell it and I am interested in buying but not sure what their MSRP was and what to offer before he decides to put on auction site. :confused:
    BTW, the manufacture site mentions it's 200 wpc at 8 ohms
    http://www.indyaudiolabs.com/aragon2002.aspx
    but another site claims it's only 100 wpc at 8 ohms and 200 wpc at 4 ohms.
    http://www.cs.cmu.edu/~eginting/txt/amps-for-thiel
    Not sure which one to believe...
  • Mystery
    So the question is what would be a fair offer assuming that if I don't like it, I can resell at least for that amount.
  • Mystery
  • soundfreak1
    soundfreak1 Posts: 3,414
    There is a 4004markll going for 650.00 asking in jax fla. on cl if that helps.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • DaveHo
    DaveHo Posts: 3,583
    That's a Klipsch era Aragon amp in the OP, which IMHO is not a real Aragon. From what I know, those were based on previous Acurus designs. I'm not saying it's a bad amp, but I would rather have an older 8008, 4004, etc over it.
    The 2002 in your other link refers to an Aragon amp produced during the Mondial days. That amp is indeed 100 WPC into 8 ohms.
  • Mystery
    DaveHo wrote: »
    I see.
    My friend also says it's 100 wpc so I'm not sure if I want to get it.
    I already have 120 wpc Yamaha M-50 and Aragon may be cleaner and high end but don't want to spend much.
    But just for offering sake, should around $200 be good offer?
