How can i maximize my current system and why?
  • PTJONES
    PTJONES Posts: 21
    edited November 2012
    tonyb wrote: »
    No, your sub has it's own built in amplifier. If you want more power to your sub you can either buy a bigger one, or a passive one and add your own amplifier.
    How can I make sure that I'm getting my maximum subwoofer power. I dont know if I'm just trying to be a perfectionist on my current system, but I know it can always be tweaked, and I always will think that I could spend a lot of money on upgrades but will it really make a huge difference on my blu ray movies, because if it does then I want it :) I definitely have a little addiction.
  • BlueFox
    BlueFox Posts: 15,251
    PTJONES wrote: »
    Turn it to 11.
  • PTJONES
    PTJONES Posts: 21
    BlueFox wrote: »
    Turn it to 11.
    HAHAHA!! I set my self up that one. Unless there is an actual 11 on my subwoofer :( I just want to make sure that I can try and get the full 300watts out of my subwoofer, after I found out that sometimes the specs can be misunderstood.
  • ken brydson
    ken brydson Posts: 9,002
    PTJONES wrote: »
    The Hitmaster goes to 11, lol...
    Damn, pic didn't post...
  • ken brydson
  • PTJONES
    PTJONES Posts: 21
    I have the DSWPRO 440 wi 8" subwoofer, and I look at the instructions and get lost. Dont get me wrong, I did hook it up but I always wondered in the back of my mind if there was a better way to hook it up so that I could get the full subwoofer effect. When I bought it I lived in an apartment, and space was limited, and I thought this was the best bang for the buck, but now that I live in a house I sometimes second guess myself on it. And earlier I found out that sometimes you need an external source to maximize the wattage of your speakers. I blindly thought that because my AVR stated 110 WPC that I was actually using it.
  • sponger
    sponger Posts: 325
    What about adding front heights? That might enhance the experience for you. I have never tried it, but I'd probably consider it if I my music to movies ratio leaned more toward the latter.
    Denon X7200WA
    LSiM 705 703 704c
    Denon DP 400
    Yamaha CDC 775
  • PTJONES
    PTJONES Posts: 21
    Lasareath wrote: »
    I had an older model of this sub. You'll never need anything more than this: http://www.sunfire.com/productdetail.asp?id=8
    2700 Watts!!
    They call it "The Lease Breaker" LOL :lol:
    Wow! That is crazy. My wife would kill me if I brought that into the house...LOL. That is defnitely a lease breaker.
  • PTJONES
    PTJONES Posts: 21
    Sponger-
    Are you talking about raising it off the ground. Right now I have the option to face the woofer down or I could face it towards me, which I havent tried yet.
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    Speakers and your room acoustics make the most difference, most big box brand receivers do well enough. Even the entry level stuff use decent dac's and as for processing the dolby dts thx and the like distribute the chipsets to all of the brands that choose the given technology. So processing is largely same. 200w per channel or 75w per channel doesnt determine how good your system will sound only how loud it can get.
    tonyb Posts: 33,072
    You couldn't be more wrong. ^^^^
  • jeremymarcinko
    Just saying power supply and Thd% most important in amplification.
  • sponger
    sponger Posts: 325
    Your AVR has pre-outs for front height speakers, which are additional front stage speakers that are placed somewhere above the mains. I can't remember if they're supposed to be above and out or above and in, but I've seen pics in the user gallery and it looks interesting as long as the owner has properly stowed/concealed the wires. Otherwise it's an eyesore with the wires dangling out in the open and down the wall.
    The manual for your AVR no doubt will help illustrate.
    Denon X7200WA
    LSiM 705 703 704c
    Denon DP 400
    Yamaha CDC 775
  • SDA1C
    SDA1C Posts: 2,072
    PTJONES wrote: »
    What kind of amp do you suggest? because Ive thought about it before but didnt know if I needed it because of my receiver
    Sorry I haven't gotten back. As far as Pioneer compatibility goes I'd say ask Noosinjohn but anything in the Adcom or Parasound will make a considerable difference and stay in the lower cost range. Possibly one of these. Though I am not a NAD aficionado. Anything of decent quality will make huge improvements.
    http://www.ebay.com/itm/NAD-2400-Stereo-Power-Amplifier-/261128713393?pt=US_Home_Audio_Amplifiers_Preamps&hash=item3ccc7bf4b1
    Disregard, I just noticed the SB/FH on the pre amp.
    Too much **** to list....
