Classe CA151 & CA180 Amps
rdb2001
rdb2001 Posts: 791
edited November 2012 in Electronics
I have found a guy locally that is selling Classe CA-151 2 channel amp and a CA-180 5 channel amp as a package. I really dont need it, but I have a friend who has been looking to move up from an all adcom amp section. Has anyone heard these amps before? The guy is asking about 2400 for the package. Is that a good deal? Just trying to help my friend out to make sure its a good deal. I personally have never heard classe gear so I thought I would post here for some guidance. Thanks
Post edited by rdb2001 on
  • zingo
    zingo Posts: 11,258
    I've heard nothing but good things on Classe amps, and I do feel they would be an upgrade from Adcom. Can he demo them before buying?
  • Tbone289
    Tbone289 Posts: 661
    A close friend of mine has a CA-201 that sounds fantastic, so I can only recommend Classe . The price seems right.
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
  • Irrenhaus
    Irrenhaus Posts: 1,101
    They look pretty good, now I am not sure about the price. I think the CA-151 is actually a integrated amp and if it is there is one in Audigon going for $1,100.00
    http://www.classeaudio.com/discontinued/specs/cav180.htm
    http://www.classeaudio.com/discontinued/specs/cap151.htm
    Cheers
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • rdb2001
    rdb2001 Posts: 791
    zingo wrote: »
    They guy does not have any speakers anymore. This is the last of a high end system that he bought a while back. We just want to make sure the current will be enough to drive some new B&Ws he just bought. everywhere we read says B&W and classe pair well and he just bought the 804 diamonds. Thanks
    Tbone289 wrote: »
    Thanks. the price seems pretty good. The 5 channel amp is a monstor at 100lbs and gets great reviews.
    Irrenhaus wrote: »
    Cheers
    It is the CA 151 which is a 2 channel amp 150 wpc in 8ohms, 300 wpc in 4 ohms.
    pitdogg2 Posts: 27,017
    the intergrated was most likely used in a second system but you can use it as a pre-amp with that 5ch amp.
  • zingo
    zingo Posts: 11,258
    If he is running B&W, than Classe would be a good choice.
    it's a good choice period Jake
  • Moose68Bash
    Moose68Bash Posts: 3,843
    I auditioned B&W Diamond 804s, 802s, and 800s -- all driven by Classe gear, and the performance was extremely good -- not good enough to get me off my Perreaux electronics and SDA SRSs -- but very, very good. One problem was that I would have neeed a subwoofer to get the sound I wanted, and I have no place for a subwoofer in my room.
    As I recall, the salesperson told me that Classe and B&W have a business relationship -- perhaps, they are owned by a common parent company, but I could be off base on this. In any case, this AV store recommends Classe electronics with B&Ws, and they sell a variety of high-end electronics.
  • Irrenhaus
    Here check this out. They are indeed.
    http://www.bwgroup.com/
    Cheers.:wink:
  • Moose68Bash
    Irrenhaus wrote: »
    Cheers.:wink:
    Thank you for sending this link.
    It's always good to know I haven't completely lost my memory -- only my confidence in it! :smile:
