lsic discontinued. need alternative
acid
acid Posts: 31
edited November 2012 in Speakers
hi i live in vancouver bc canada. we have a very poor selection. I never picked up a center channel when I should have. so Dilemma I can't get a matching center. can you all suggest an alternative?
i've searched ebay amazon google shopper and many more.. so if there is an equivalent to the lsi15's I have I would really appreciate any input
  • falconcry72
    falconcry72 Posts: 3,580
    The LSiC is the only matching center for your LSi15's. Look on ebay or local craigslist or canuck audio mart etc, one will come up eventually.
    Another very good alternative would be to just use a single LSi7 or LSi9 bookshelf speaker as a center. In my testing, a single LSi9 actually sounded better than the LSiC. Hands down.
    Good luck!
  • acid
    acid Posts: 31
    thanks for the advice i'll look into it
  • PubFiction
    PubFiction Posts: 105
    You can call polk and see if they have any LSiC refurbished too, not everything makes it to ebay. I just bought a pair of LSi9 and will use one for the center. I would imagine others have done the same and they will show up on ebay. But even the LSi9 is getting hard to find. The Lsi7 is plentiful though.
  • acid
    acid Posts: 31
    a guy is selling two here in vancouver for 600 can i Daisy them? he won't sell just one
  • falconcry72
    acid wrote: »
    It would be better if each speaker was on its own amp channel. you could just sell the other one.
  • nocdavis
    nocdavis Posts: 1
    I got this response when I asked Polk a good replacement for the LSiC
    A much better choice would be the LSi M704.
    Another option would be a CSiA4 but this speaker will be a little brighter by comparison.
  • Drapolas
    Drapolas Posts: 12
    I was debating If the LSiM704c would be a good replacement as well. There are some occasional LSiC on eBay but they are not in mint or great shape, and the LSiM704c will be under warranty. Would an LSiM704c match (timbre, and overall seamless front stage) the LSi15s, LSiF/Xs in surround, and LSi7s in rear surround? A few Audio equipment dealers mentioned that it is a good alternative, but I want to hear the unbiased opinions of fellow polkies. Thanks!
