Car stereo with tubes?
Clipdat
Clipdat Posts: 13,101
edited November 2012 in Electronics
Anyone ever seen anything like this before? http://uncrate.com/stuff/panasonic-cq-tx5500d-vacuum-tube-car-stereo/
I'd imagine you'd have to have some pretty good speakers and sound deadening material in your ride before you would notice the influence of tubes on your signal, especially while traveling at speed.
That being said, I would rock this thing in a heartbeat if I could afford it. Especially love the analog VU meters. Of course this thing would look much more at home in a high end Benz or Lexus and not my lowly Scion tC.
Thoughts?
Post edited by Clipdat on
    txcoastal1 Posts: 13,519
    Would actually go great in a 50's ford or chevy restore truck
  • zingo
    zingo Posts: 11,258
    I agree it would be awesome in a restoration!
    treitz3 Posts: 20,290
  • Syndil
    Syndil Posts: 1,582
    This model has been around since at least 2002. If you're considering buying one, you might want to double check what market it was made for. AFAIK these were only made for the Japanese market and therefore are set up for Japanese FM/AM, which is in a different range than US FM/AM. Japan uses 76 to 90 MHz where we use 87.5 to 108 MHz. You'd need a band expander to make it work, and even then it would show the wrong tuning frequency on the display and would not be able to tune to the entire US range.
  • skrol
    skrol Posts: 3,488
    That is pretty wild. I wonder if they have any issues with all the road vibrations and bumps. That Panasonic screams for a wider opening to plug in an 8-track tape.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    Syndil wrote: »
    Good tip! I'm not seriously considering one, but still nice to know. Fortunately for me I can't stand anything on FM radio!
    treitz3 wrote: »
    Only 4 grand?!? I'm getting two!
  • Jer.War
    Jer.War Posts: 180
    A good friend of mine has this deck in his truck. He loves it and it sounds great. He also has a tube amp feeding the fronts and rears in his setup. The whole setup sounds great. He has had the deck for 4 or 5 years without any issues....
    [The Ever-Evolving System
    LSI15's (PNF Symphony cabels, modded X-Over and subs), LSIC, LSI7's, Rega Apollo CDP (PNF ICON ICs, modified PS cct.), Yamaha RXV-1700 w/ ipod dock, B&K REF200.2 (fronts) Samsung BDP-1600, XBOX360, Patriot Box Office Media Player, 42" Samsung LCD.
