What value resistor is this?
zingo
zingo Posts: 11,258
edited November 2012 in DIY, Mods & Tweaks
I want to confirm this is 47ohm, not 4.7ohm before I order:
Post edited by zingo on
  • soundfreak1
    soundfreak1 Posts: 3,414
    Bad boys rape our young girls but violet gives willingly.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • FTGV
    FTGV Posts: 3,650
    :arrow:.47:arrowl:
    mhardy6647 Posts: 35,377
    Good mnemonic but in this case it doesn't help much - it's a sand cast power resistor :-P
  • gimpod
    gimpod Posts: 1,793
    Wouldn't a 0.47 Ohm be 0R47?
    Measure it to be sure.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Looks as it is a .47 Ohm 7 watt.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • zingo
    zingo Posts: 11,258
    I think you guys are right that R47 is .47 as it measured under 1 ohm in the circuit.
  • zingo
    zingo Posts: 11,258
    Thanks everybody! Order two Mundorf .47 MOX resistors to replace the sand blocks as part of my XO refresh. It's on the mid/high board of the XO, so if I got the value wrong, the tweeter will just be hotter, as the resistor was a late addition to the run of the speakers anyway. I'm excited to hear the diference with replacing sand block resistors and 15 year old electrolytic caps!
  • soundfreak1
    Yea i had to burn some braib cells to pull that back up. But only good on std. Resistors.just wanted to see if anyone would know what it was. HeHe u showed your age .they tought us yhat back in 1972 in electronics school.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    Yea i had to burn some braib cells to pull that back up...
    braib cells?! I think it's even worse than you thought!
  • Tbone289
    Tbone289 Posts: 661
    zingo wrote: »
    The caps in your picture aren't electrolytics. They're metallized polypropylene (MPT).
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
  • zingo
    zingo Posts: 11,258
    Correct, but the caps on the woofer board are electrolytics. I will also be replacing those MPT caps with newer and closer tolerance ones, with the ultimate goal to upgrade them to Mundorf to match what the factory releases currently. :cool:
  • Tbone289
    Tbone289 Posts: 661
    Right-o. Just wanted to be sure... Good luck with the upgrades!
  • zingo
    zingo Posts: 11,258
    Received all the parts for my crossover update: MOX resistors and 1% poly caps. Should be able to get them installed this week, and interested to hear any changes. I'm not expecting a lot as I didn't go crazy on parts, but improvements may come if current poly/electro caps have drifted out of spec. Plus, switching from sand-block to MOX resistors should open things up a little.
  • zingo
    zingo Posts: 11,258
    Is this a 7uF capacitor? The schematic for the speakers say this should be 5.3uF in the woofer XO, so I picked up a 5.7uF without actually checking the board. My pair of speakers are late in the production, so maybe B&W tweaked a few things by that point.
  • Tbone289
    Tbone289 Posts: 661
    Yes, that is 7uf.
  • zingo
    zingo Posts: 11,258
    Thanks. I know it was a stupid question as a big 7 is printed on the side, but I just wanted to confirm with others as it does not match the schematic.
  • disneyjoe7
    7uf 70 working volts and non Polarized
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • zingo
    zingo Posts: 11,258
    Thanks for the confirmation. I'll be replacing those caps with these, in my task to bring the crossovers up to current B&W production specs. Time to place another order...
  • ViperZ
    ViperZ Posts: 2,046
    disneyjoe7 wrote: »
    Why would you say that there is no "----" stripe on the other side? Looks like an electrolytic cap to me.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • FTGV
    FTGV Posts: 3,650
    It is an NPE( non polarized electrolytic).The indentations at both ends (not just one) is also an indicator of such.
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    1972 ? BEEP in SD, CA ? Then ETA (R, SPS10) on TI in SF, CA ? NPS at MI, CA ? NPTU at IF, ID ?
    Mnemonics, or numb-onics, I'm not sure. :wink: Sorry, I got sidetracked again. :redface:
  • zingo
    zingo Posts: 11,258
    FYI; just order the Mundorf caps from Parts Connexion and got 20% off! Forgot they were having a sale, but it does end this month, so order-up some Thanksgiving for yourself; or a loved one...
  • zingo
    zingo Posts: 11,258
  • disneyjoe7
    Nice and Clean, how do you like the sound?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • zingo
    zingo Posts: 11,258
    Since only one speakers is done right now, I put on a song that has a similar pace and tone all the way though (Texas Rangers by Rebecca Pidgeon), set my preamp to mono, then used the balanced to switch between my left and right speaker. With only a little time on the components, I already could hear a difference between the two speakers. The upgraded speaker has less sibilance which is the most notable change. Along with that, the decay of sounds is much quicker and cleaner, and sounds are more defined; more sharp. The unmodified speaker sounds in comparison a little warmer and softer, but also more fuzzy around the edges; a little less defined. I'll be interested to hear both with stereo music once I finish the left speaker, but those B&W speakers are built like tanks and every step takes longer to upgrade them.
    I don't know specifically what to attribute the change to, but I'm sure it's many things at once. The MOX resistors will make a difference, as will having caps that are within 1% of eachother left to right; and no more electrolytics. I also like that when I'm finished, the new components will be Mundorf, which updates the speakers to match what the factory is producing now.
    More to come...
  • zingo
    zingo Posts: 11,258
    Second crossover upgraded. Now let the burn-in begin...
