SVS Equalizer
Early B.
Anyone use the equalizer that SVS sells on it's website?
Any real reason to use one?
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
If you are refering to the Rane model, I havent seen anyone using it. Probably because the BFD is 1/3 the price.
You use a PEQ to tame the frequency response. They are great for knocking down room peaks but not great for helping with nulls.Graham
