SVS Equalizer
Early B.
Early B. Posts: 7,900
Anyone use the equalizer that SVS sells on it's website?
Any real reason to use one?
"God grooves with tubes."
  • gatemplin
    gatemplin Posts: 1,595
    edited May 2004
    If you are refering to the Rane model, I havent seen anyone using it. Probably because the BFD is 1/3 the price.
    You use a PEQ to tame the frequency response. They are great for knocking down room peaks but not great for helping with nulls.
    Graham
