Bel Canto's USB > SPDIF Converters
falconcry72
falconcry72 Posts: 3,580
edited November 2012 in Going Digital
Anyone have any experience with Bel Canto's new USB > SPDIF converters???
They offer (3) levels:
- mLink: $400: http://www.belcantodesign.com/Belcanto_mLink.html
- uLink: $700: http://www.belcantodesign.com/Belcanto_uLink.html
- REFLink: $1500: http://www.belcantodesign.com/Belcanto_REFLink.html
Wondering if any of these would be an upgrade to my Audio GD Digital Interface. Gotta have a good source!
Post edited by falconcry72 on
    SCompRacer Posts: 9,137
    The source is everything...
    One important thing with USB to SPDIF/I2S interfaces is to maintain galvanic isolation between the PC and destination via transformer coupling. IIRC all the Bel Canto's you linked do that. Gotta isolate that harsh 'putie environment to get the best SQ.
  • Ern Dog
    Ern Dog Posts: 2,237
    Also consider Empirical Audio Off Ramp 5. This USB converter has transformed my PC audio rig so that it is outperforming my cd player. It sounds very natural and realistic.
  • falconcry72
    Ern Dog wrote: »
    The Off Ramp is high on my list as well.
  • bikerboy
    bikerboy Posts: 1,235
    I received the Amanero usb to i2s converter and find the pc sounds better than ever. Will your Audio GD NFB-7 accept i2s?
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
  • falconcry72
    bikerboy wrote: »
    No i2s. Only AES/EBU, BNC coax, RCA coax, and Toslink.
    Don't get me wrong, my Audio GD Digital Interface sounds great... I'm just always questioning whether it's a bottleneck, given that it ran 200 bucks, whereas all the other components in that system retailed for a few k when new.
    The DI sounds as good as the CD transports I've compared it to, but I'm wondering if a better converter will be even better...
  • falconcry72
    Can't for crap for reviews on these converters... must be real new. That also means they won't showing up on the used market for a while. I don't want to be a guinea pig for the $1500 reflink, but damn it's tempting!
    I hate the depreciation aspect of buying new myself.... If it becomes as popular as the Wyred DAC's, resale could be high.
    I like that they have a BNC coax input on your Audio GD....a true 75 Ohm connector. Best way to reduce chances of reflection in that SPDIF signal compared to RCA in. With digital, you have to look at all ways to get best possible sound.
  • falconcry72
    SCompRacer wrote: »
    On the NFB7, I've been using the BNC input for my DI and the AES/EBU for my ARC CD-1. The RefLink has both AES and BNC out, so I'd probably try both.
  • dorokusai
    dorokusai Posts: 25,576
    We used the brand new BelCanto DAC with SPDIF at CAF2012 and have nothing but high reviews for them. We had a BLACK BOX uLink version direct from Engineering so not sure what has changed to production but it was awesome. We did have to reset it a number of times for whatever reason but this went back to them as a downside comment.
    Our iTunes interface was Pure Music. I was told by BC that they preferred that connectio(SPDIF) over optical and digital output anyways....take that for what its worth.
    Mark
  • falconcry72
    dorokusai wrote: »
    Mark
    Very cool. Does Polk work with BC a lot? Which model DAC was it? That's encouraging that your ulink prototype performed well... makes me even more tempted by the reflink...
