Need an AMP - what do you suggest?
jwl
Rats! My Adcom GFA-535 does not work, so I need an AMP (not a receiver). My preference is for clean, accurate and tight sound. I mostly use the speakers to play music, some videos and occasional films/presentations.
I am wondering what makes more sense
1. Get another Adcom GFA-535 or similar on eBay
2. Purchase a Emotiva UPA-200 or Mini-X A-100
3. Something else
Here is the equipment I am using (I pasted links to manuals below). This is connected to a computer and it is critical that the sound be controllable by the computer (hence no receiver).
Polk Monitor 40 Series II
Polk PSW10
HT Omega eClaro (PC sound card)
If needed, I have a Klipsch Promedia dd 5.1 preamp/decoder
Polk Monitor 40s: http://ec1.images-amazon.com/media/i...L000074437.pdf
Polk Sub: http://www.polkaudio.com/downloads/m...SW10_12_MN.pdf
HT Omega eClaro: http://www.htomega.com/filedown/eclaro.pdf
klipsch dd5.1:
http://www.klipsch.com/promedia-dd-5-1
http://www.themusichelpers.com/z/248061100000001
3. Something else
Polk PSW10
klipsch dd5.1:
Post edited by jwl on
Parasound 275? They are known for their sound quality.
http://www.audioadvisor.com/prodinfo.asp?number=PAC275 -
Got a suggestion on another forum for an ATI AT602. Found one for under $300, but I do not see a lot of information/reviews on it. Does anyone know how it compares to the Adcom GFA-535, Emotiva UPA-200 and Clipdat's suggested Parasound 275?
J -
I bought the ATI. Good reviews, great price and 7 years of warranty.
Thanks for all your help -
parasound 275? They are known for their sound quality.
http://www.audioadvisor.com/prodinfo.asp?number=pac275
x2....Samsung UN55C6500 55" LED
Onkyo TX-NR3007
Polk Audio RT5000
-RT3000 front
-CS1000 center
-FX1000 dipole
Polk Audio PSW1000 5.1 sub
Polk Audio microPRO 4000 x2 5.2 subs:biggrin: -
I'd stick with finding a new amp if it's within your budget. Otherwise, the adcoms always work for a while.Fronts:B&W 804 Diamonds, Center: B&W HTM2 Diamond, Surrounds: PolkAudio LSi F/X (4)
Subwoofer: HSU VTK3-MK3
Electronics: Onkyo TX-NR 3010 receiver, Parasound Halo A31 amp, NAD T975 amp -
Is the Adcom repairable? Depending on its issues it could be an option. It could also be a money pit as I found out first hand. :cheesygrin:
Didn't you just buy that Adcom? I remember the thread you started in the speakers forum not too long ago.Denon X7200WA
LSiM 705 703 704c
Denon DP 400
Yamaha CDC 775 -
You can also investigate possibly buying a new Adcom amp directly from them. Not too long ago I emailed them about thier trade in program. If they still have that promotion going, you might consider trading in the broken one for a newer one directly from them.Fronts:B&W 804 Diamonds, Center: B&W HTM2 Diamond, Surrounds: PolkAudio LSi F/X (4)
Find a used B&K ref200.2 , it's a fantastic amp and if you plan down the road to get better speakers. A nice used Rotel RB1080 is also a pretty killer amp. Both amps will cost you under a grand on the used market , maybe like $400-$700 depending on condition.Dan
The Parasound HCA 1000A, which has a bit more power than the Adcom GFA-535, can be had for $200-250. I went to a Parasound HCA 1500A, from an Adcom GFA-545, and was very happily surprised. Fuller, more detailed, more lush.
Yes, lush. My LSi9s love this amp.
I'm all over these forums pushing Parasound, because of my recent upgrade. Quite an improvement. And I love Adcom.Marantz CD6004
Adcom GFP-750
McCormack DNA-1
Polk LSi9s
Signal Cable ICs
Blue Jeans cables -
What about a carver . I love mine.
I preffice this with ( im a parasound fan) having said that... Look at parasound. Great amps warm and lots of currant, and fairly available. Goof reliability and just sound fantastic.also available in many power ratings and price ranges.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
SugarmillMan wrote: »I'd stick with finding a new amp if it's within your budget. Otherwise, the adcoms always work for a while.Find a used B&K ref200.2 , it's a fantastic amp and if you plan down the road to get better speakers. A nice used Rotel RB1080 is also a pretty killer amp. Both amps will cost you under a grand on the used market , maybe like $400-$700 depending on condition.The Parasound HCA 1000A, which has a bit more power than the Adcom GFA-535, can be had for $200-250. I went to a Parasound HCA 1500A, from an Adcom GFA-545, and was very happily surprised. Fuller, more detailed, more lush.
I'm all over these forums pushing Parasound, because of my recent upgrade. Quite an improvement. And I love Adcom.What about a carver . I love mine.soundfreak1 wrote: »I preffice this with ( im a parasound fan) having said that... Look at parasound. Great amps warm and lots of currant, and fairly available. Goof reliability and just sound fantastic.also available in many power ratings and price ranges.
You guys read much?? He already bought something... see post 4. Never heard of an ATI AT602, though... maybe he'll report back. Evidently, it's good for "powering a pair of exotic audiophile speakers or stringing together a yard full of outdoor speakers." Curious. -
mdaudioguy wrote: »You guys read much?? He already bought something... see post 4. Never heard of an ATI AT602, though... maybe he'll report back. Evidently, it's good for "powering a pair of exotic audiophile speakers or stringing together a yard full of outdoor speakers." Curious.
I'm sorry. I just really wanted to recommend a Parasound.
It won't happen again.
Ed Frias likes ATI, and he makes really good speakers.Marantz CD6004
Adcom GFP-750
McCormack DNA-1
Polk LSi9s
Signal Cable ICs
Blue Jeans cables
