MIT Shotgun S3.3 Cable Demo/Review Round 4
    EndersShadow Posts: 17,759
    edited September 2012
    Clipdat wrote: »
    Is there a minimum baseline equipment/speaker "spec" that would be needed in order to demo these cables?
    I will let F1NUT chime in but I believe the answer to that is a resounding NO. As long as you provide your contact info and meet the other requirements there is not one for gear.
    I will however say whatever F1NUT says is the truth on this (in case I am wrong)
  • Drenis
    Drenis Posts: 2,871
    Clipdat wrote: »
    Just whatever is listed for "Requirements" in post #1.
    treitz3 Posts: 20,360
    Hey, Jesse. I thought more folks would be up on the list. Kinda surprising with the few amount of folks that seem to be interested in checking them out. Anyhoo, I'm currently running the Transparent Reference IC's between the Dodd, Jolida and MF amp with the AQ CV-8's w/ the 72v BP upgrade for SC's and I'm open to trying these out if there are no objections. I believe you still have all of my contact information as nothing has changed there but I'd be happy to provide it all again if needed. Call me if you wish.
    Just LMK bro'.
  • IRLRaceFan
    IRLRaceFan Posts: 172
    Hi everyone,
    First let me say that anyone even curious about trying these cables needs to sign up - it's a no brainer!
    Also, thank you Jessie & MIT for this opportunity and for supporting this demo.
    Up front, I already own MIT interconnects & speaker interfaces (cables), as well as competitor products from Signal Cable, Nordost, Transparent, Monoprice, and Monster. I wanted to compare the new 3.3's to my S1 & S3 components. I also did a comparison to a complete Signal Cable Silver Resolution set up. I would have done more, but didn't have enough time with work & school.
    Equipment List
    Speakers: Magnepan 1.7
    Amp: Carver M1.5t (rebuilt/upgraded by Hi-Tech Audio, 2011)
    Pre-Amp: Cary Audio SLP 30
    DAC: W4S DAC-2 w/ Audio-gd Digital Interface (V1)
    Source: Apple Mac Mini, iCore 7, 2.7-GHz, Mountain Lion OS
    Software: Pure Music (Channel D)
    Music Selection - All Digital
    All of the music I selected is Rock, but with a varying degree of "heaviness":
    The Raven - The Alan Parsons Project; 16-bit / 44.1kHz FLAC
    Tom Sawyer - Rush; 24-bit / 96kHz FLAC (HD Tracks 2012)
    L.A. Woman - The Doors; 16-bit / 44.1kHz FLAC
    Another Brick In the Wall (Part 1 & 2) & The Happiest Days of Our Lives - Pink Floyd; 16-bit / 44.1kHz FLAC
    The End - The Doors; 24-bit / 96kHz FLAC (HD TRacks 2012)
    Nightmare - Avenged Sevenfold; 16-bit / 44.1kHz FLSC
    The Ubiquitous Mr. Lovegrove - Dead Can Dance; 16-bit / 44.1kHz / 256kbps AAC
    Listening Configurations
    1) MIT Shotgun S1 & S3
    DAQ --> Pre: S1
    Pre --> Amp: S3
    Amp --> Speakers: S1
    2) MIT Shotgun S3.3
    3) Signal Cable Silver Resolution
    4) MIT Shotgun S3.3
    5) Signal Cable Silver Resolution
    6) MIT Shotgun S3.3
    I listened to config's 1-3 by myself and had a friend over for 4-6. She is very familiar with my system, so I had her listen to the new MIT's vs. Signal. I did what is referred to as an A-B-A test to see if her initial impressions of the MIT's repeated.
    Results - Impressions
    I did notice a slight difference between the new MIT's and older S1 & S3's. I'm not an audio engineer or expert, so my best way to compare is to just say it seemed different at some frequencies for some songs - I feel like the 3.3's have a slight edge.
    The difference between the 3.3's and Signal Silver was more noticeable. I found the Signal's to have a degree of harshness the 3.3's didn't. My friend said there is a definite difference in sound. She didn't point out a harshness with the Signal's like I did, but she did prefer the 3.3's.
    In all cases I found the 3.3's to have detail without harshness (this is a big deal for me). Some songs like The End & The Ubiquitous Mr. Lovegrove had a much better 3D like soundstage and slightly more detail than the Signal's.
    I also want to say that I've read on this site about some having issues with MIT interconnects & W4S DAC's - this has never been the case for me.
    Conclusions
    I do like the 3.3's, but I'm not rushing to upgrade right now.
    My friend has listened to my system throughout all of my different upgrades and said this wasn't much of a change in comparison to other things I've done. She specifically said it wasn't enough for her to get very excited over, because she's seen (heard) what other changes can do. The Signal's would be good enough for her, especially from a cost perspective. I don't share her opinion completely, because I really appreciate the detail of the MIT's without harshness. I want that 3D like soundstage where it sounds as if you could reach out and touch the instrument being played; the MIT's seem to contribute to that.
    I'll admit to a preference of MIT products, but also have some criticisms. The products are well built, but the cables are a bit stiff & not as flexible as other brands, plus the network boxes take up space and they do mass-load connectors (if the boxes are unsupported); so they might drive some people with OCD a little crazy.
    I don't think anyone starting out in this hobby should make cables like these their top priority. To me these are like the final touch that helps you get that last few percent out of your system - spend your money on speakers, amp, pre, and source first and then consider this level of cables. In the meantime, there are good midlevel cables out there that can be bought used & re-sold without too much loss on investment.
    BR;
    Shaun
    HT
    Onkyo TX-NR1008 | Magnepan 1.7 | Polk LSiC | Polk VM20 | Polk DSW microPro 2000 | Parasound HCA-2205A | Oppo BDP-93
    2-Ch
    Cary SLP 30 Tube Preamp | Polk LSi7 | Carver M1.5t | Audio-gd Digital Interface | W4S DAC-2 | MAC Mini | Denon DP300f & Pro-Ject Debut III TT's
  • Mike Reeter
    Mike Reeter Posts: 4,315
    Good write up Shaun, It seems to be a common denominator that the MIT's bring "Detailed and Revealing" to the table, without being harsh or overly bright. A tough nut to crack for some cables.
    I'm looking forward to this demo myself one day!
  • engtaz
    engtaz Posts: 7,676
    edited October 2012
    Nice review thanks.
    engtaz
  • SDA1C
    SDA1C Posts: 2,072
    edited October 2012
    I wonder if any of the gain is diminished by not upgrading the SDA IC along with the 3.3. I very well could have missed it but I do not recall any on es review of an upgraded IC beyond what was already in place. Thought's?
    Too much **** to list....
    F1nut Posts: 52,406
    edited October 2012
    SDA1C,
    That's not what this demo is about, nor does everyone trying these cables have SDA's, so let's keep it on topic. Please and thanks.
    treitz3,
    I sent you a PM, but I'll say it here too. For some reason MIT cables and Dodd pre amps don't like each other. Therefore, it would not be a good idea to test that again.
    Clipdat,
    Sorry, at this time you do not meet the time requirement.
    Clipdat Posts: 13,104
    edited October 2012
    No problem! I am planning on sticking around the forum, so eventually I will have my chance to try out the cables! :biggrin:
    edited October 2012
    Hello, Larry. If I recall correctly, you had the Dodd ELP. I don't know if it makes much difference with regards to MIT and Dodd with the model I have. I've got the MLP preamplifier [the one Ted and George Daniels used to own]. I did get your PM Jesse. I just never responded. Really didn't know what to say. I do trust that if you have knowledge that I don't, there's no sense in wasting anybody's time. The Transparent Reference IC's work great with the MLP. In fact, they are the best cables I have heard in the rig to date. They really make the Musical Fidelity amplifier sing with the utmost of authority , while at the same time, finesse.
    Basically, I trust Jesse. If he tells me that they don't match well with the Dodd, then I'll take him at his word. He hasn't steered me wrong yet. Well, with the exception of him preferring MIT *pokes stick at Jesse a couple of times* Hehe.
  • SDA1C
    SDA1C Posts: 2,072
    edited October 2012
    Yea. Good point. Sorry for the derail..
  • vcwatkins
    vcwatkins Posts: 1,992
    edited October 2012
    F1, your box is full.
  • vcwatkins
    edited October 2012
    Thanks Jesse and MIT for the opportunity to try some very impressive cables and learn something along the way.
    I joined the forum about a year ago and haven't attended any events, so no one really knows me from Adam. You can see my system is meager compared to most here, but I am very pleased with it at this point and hope I've reached a sort of plateau where I can be happy for a year or two. I was very curious to learn how much a lower end system like mine might benefit from a cable upgrade. Value is the primary factor in 95% of my purchase decisions, so my goal was to get a better picture of the cable cost/benefit curve by participating in the demo.
    Equipment Used
    Source: Squeezebox Touch (Welborne PS)
    Cable: MIT T3 coax
    DAC: Arcam rDac
    Cables: MIT EXP1 rca
    Pre-Amp: Dared sl2000a (Telefunken 5965), Adcom GFP-750
    Cables: MIT Proline xlr's
    Amp: Emotiva XPA-2
    Cables: MIT EXP2
    Speakers: Polk SRS 1.2 (rdo's, rings, dynamt, armacell)
    Listening
    In order to avoid confusion, I did not use any other sources, speakers, or electronics until after the testing was completed. All tunes are flac, some are 24-96, and, wherever available, mfsl versions. Here's what I did:
    1) Listened to several familiar songs in a demo playlist with existing cabling (EXP2's)
    2) Installed the Shotgun S3.3 SC's and IC's
    3) Listened to demo playlist for ~2 hrs, making notes on all
    4) Listened to other music without making many notes
    5) Following night - listened to assorted music ~2hrs, adding just a few notes as needed
    6) Following few days - tried other sources, vinyl, tubes for ~ 1hr each night
    Tasting Notes
    Steely Dan / Aja /Black Cow - Background vocals much easier to discern individual voices. Voices seemed more natural & lifelike. Cymbals sparkle.
    // Aja - Percussion like raps on the little wood thingies really pop. Metallic tinkles really shimmer. I'm feeling very giddy at this point hearing the system sound so good. Familiar songs sound new somehow. Sax solo seemed to be inside the room. Lower end seems to extend a bit lower than before. Cymbals sound amazing. Kettle drum (?) sounds true, more realistic.
    Steely Dan /Gaucho / Third World Man - Less mid warmth but, but string texture on guitar seemed fuller with added detail.
    Adele /19 / Make You Feel My Love - Voice, when starting a phrase & going lower with a bit of growly grain, sounds more detailed and organic.
    Ortophonk / Massala Films / Han's **** - LOW, muscular, tight, room-shaking bass. I was apparently liking it - I scrawled "Extra large funk for you! Cood gawd ya'll!"
    Rodney Hunter / Hunter Files / Work That Body - Everything just seemed a bit smoother and more detailed. Lower bass extension. At this point I realized I had been moving, couch-dancing, tapping, whistling etc a whole lot. Really enjoying the music.
    Fleetwood Mac / FM1968 / Long Grey Mare - Snare very realistic! Harp sounds a bit thin and harsh at times. Overall the sound was a bit too dry (not something I've noticed before). Disappointing as this is one of my all-time faves.
    Fleetwood Mac / Blues Jam in Chicago / Horton's Take 1 - Separation and location is improved. Excellent guitar! Drums and bass are pushed way outside left to ~ 9:30 or 10:00. Sounds so good!
    ABB /Eat A Peach / Mellissa - Rhythm guitar is detailed & sweet. Instruments are a bit easier to precisely place in the soundstage. Keys near the end sound truer somehow.
    Earth Wind & Fire / All'n'All / Runnin' - Rhythm and keys stand out. Everything seems fast and more detailed. Smooth vocals. Dense sections are a bit clearer than before. Horn solo decay and syncopated percussion POPS! End section GROOVES!
    Cracker / Kerosene Hat / Kerosene Hat - Noticeably bigger bass, more detailed guitar strumming. Wow! The band is right here in front of me. The whispers have never been this clear. In fact I didn't realize they continued for that long a stretch til now. Cymbal taps are crystal clear and just magical.
    Linn Selektions Demo / Black Coffee - Keys are fantastic! Voice not too far forward, very smooth and organic. Lovely.
    Elton John / Honky Chateau / Rocket Man - Less warm - very disappointing since this is a fave demo. Background vocals pop out better.
    //Honky Cat - Keys are better, banjo a bit more prominent. Great detail.
    Apples / Buzzin' About / Stack It Up! - Group vocals more discernible as individuals. Good punch. Bass line KICKS! Noticed toy piano (or xylophone) for first time.
    Art Blakey / Caravan / Caravan - Drum intro excellent - when he moves to rim & cymbals, it's like the drum kit is in room with me. Unbelievably accurate instrument location. Horns' every nuance is revealed. Sax seems thin however. Drum solo amazing. Very engaging overall.
    Eric Clapton / Slowhand / Lay Down Sally - Both guitars seem lighter on their feet. Less warmth - "prancing ponies" iso "wild thundering herd". Acc vocals more pronounced. I like this better overall, even though I'm usually a warmth addict. Better soundstage here too. Best I've heard this sound.
    World Party / Goodbye Jumbo / Way Down Now - Opening too harsh. I think this is an example of revealing a poor recording even though this is remastered.
    // Take It UP - Guitar so good. Better detail throughout. Improvement.
    XTC / Apple Venus / River of Orchids - Amazing detail in water dripping & strings. Drips seem to linger 3-dimensionally in space.
    Conclusion
    As compared to MIT EXP2 speaker cables and lower level MIT interconnects on my system, the Shotgun S3.3's provided improved detail, more precise location of sources, improved bass extension, outstanding shimmer on cymbals & other UHF. Voices, drums, and other percussion seemed more organic. Even on my meager system, the improvement was easily noticed and not insignificant. And, although I am not likely to purchase these in the next year or two for this system, when I do start making wholesale upgrades, I am very likely to consider the S3.3's.
    Craig
  • engtaz
    engtaz Posts: 7,676
    edited October 2012
    Thanks nice review.
    engtaz
    F1nut Posts: 52,406
    edited October 2012
    This is too funny....first the demo list disappeared from the first page for no reason, so I added it on this page. Now, it's back on the first page and has disappeared from this page. WTF???
    Anyway, SDA1C and Slinger182 have been added to the list. Indyhog asked to moved down the list again.
  • Mike Reeter
    edited November 2012
    With much regret, I have shipped the MIT's to their new temporary home. I want to thank Jesse and whoever else has been responsible for the Demo Offer. What a great way to try out a High End product in your own environment, with no pressure to buy.
    I have declined taking part in the Cable Demo offerings in the past, as I was affraid of what might come of it. Knowing full well that cables DO matter, I was almost affraid of what I might experience. My Audio Fund always seems to be "tapped" and there was never enough cash to afford much of a cable upgrade.
    I knew from the previous posts that the MIT cables were of good size, but I had no idea of just how effin' BIG these things were until I unboxed them...wow, I took a couple of pics just to show their masculinity. I REALLY liked the RCA connectors on the i/c's, the locking function of the barrels is a nice touch, have never used any connectors like these before...sweet.
    The choice of terminals for the speaker wires is also a very nice touch, supreme versitilty. The term "You get what you pay for" comes into play here.
    I have a simple two channel rig, A Rogue Audio Cronus Magnum Integrated, a Jolida JD-100A cdp for a source, pair of modded SDA 1C's and a newly restored pair of SDA 3.1TL's.
    My current speaker wires are some Signal Cable Ultra and some Audioquest King Cobra i/c's. My room is pretty well treated and the imaging and the sweet spot are dead center.
    I hooked up the MIT's, let the tubes warm up, grabbed a cool brew and selected some of my "go-to" music, the cd's that are the best of my small collection that shine. I was literally taken aback by what I was hearing, it was a jaw dropping moment for sure.
    I can't say anything more about the MIT's that hasn't already been said by the previous members comments, but I can say that my rig has never sounded better. The MIT's have brought everything to the party, the imaging, clarity, precision, depth and width of the soundstage, it's all there in spades. And the Bass, clean and tight and well pronounced. I now know what "air" sounds like, and I liked what I was hearing. It's like the cables have pulled everything together and made a major improvement in the overall presentation, the same as a new piece of gear brings to the table.
    btw, speaking of hearing, I am hearing impared, to the point I'm forced to wear hearing aids most of the time. But, I always remove them to listen to music, the aids have a very digital sound to them, I can't stand to listen to music with them in, I just have to turn up the volume a little on the amp to compensate. Even with my hearing issues, I was picking up on little things I had never noticed before. If a set of cables can do this me, I'm sure that anyone with "normal range" hearing could also hear improvements in every area.
    The Shotgun 3.3's could very well be the last cable I would ever want or need in my set-up, the MIT's have shown me what my rig is capable of and what a "Really Good" set of cables can bring toward that thirst for Audio Nirvana that most of us crave. I have been saving for some time to purchase a new Vinyl front end, but I might have to postpone that one for some time later down the road...I can see some MIT's in the mix one day for sure.
    Thanks again for this opportunity, I loved every minute of it.
  • agfrost
    agfrost Posts: 2,497
    Nice review! I miss them too. :cry:
    Jay
  • engtaz
    engtaz Posts: 7,676
    Very nice review Thanks
    engtaz
    heiney9 Posts: 25,710
    Nice review Mike, listening is believing and that really is the ticket, so to speak, in this hobby. Many, many years ago I was skeptical of MIT cables and their cost. Once I got it in my fat head to try several lines, I finally settled on The Shotgun series for my main rig and Terminator 2's for my two secondary rigs.
    They are the real deal and cables matter.
  • Mike Reeter
    heiney9 wrote: »
    That's why I put the trial demo off for so long, I knew from the comments from MIT owners around here that they WERE the real deal, and I would be left with the feeling of "Cable Envy" until I was able to be an owner myself.
    A few years back when I tried my first set of "better" cables, I picked up some Blue Jean Cables, a pair of Audioquest Mambas, some Copperhead i/c's and I was pleasently surprised at what I was hearing. I ended up with some King Cobras that are a solid performer also and have served me well over the years.
    Have tried a few speaker wires including some IXOS, Audioquest Bedrock and some Signal Cable Ultras, all better than average wire, but not in the same league as the MIT S3.3
    I live in the middle of nowhere, it is a 180 mi. round trip to the nearest dedicated Audio Store were a guy can see and demo anything that resembles Hi Fi. So I really appreciate the offer to try out some very nice wires and cables in my own home, with my own gear, and my own material.
    Santas list is getting started a little early this year!
    If you are vigilant and scour Ebay and Audiogon a few times a day, you can find some great deals, but you have to act fast. I paid a fraction of retail buying used and all mine look brand new. The only downside to being "cheap" :cheesygrin:, is I waited quite awhile to get a complete set of Shotgun cables for my rig. But for the price I assembled it all, it was worth the wait.
  • Mike Reeter
    Hey, I'm all about buying " good used " I quess another term for being " cheap " !!!
    Hey Mike, nice review! You did a great job describing the build quality and fit & finish of these high end cables.
    Can only imagine how awesome the tube amp & CDP sounded together with the MITs - Looks like we know what you want for xmas!
  • Mike Reeter
    Thanks Drew, the demo was an "ear opening" experience for sure. Well worth the price of admission :biggrin:
  • SDA1C
    SDA1C Posts: 2,072
    Hats off to Jesse and MIT for the opportunity to audition a grand set of interconnect and speaker cables at such an outlandishly low cost. Anyone considering an upgrade of this type should definitely get on the list for what is, if nothing else, an opportunity to verify or put to rest the great cable debate.
    Equipment;
    Sunfire TGP3, Sunfire Sig425/5, Oppo BDP-93, Belkin PureFilter60, Technics 1360 TT
    Current cabling;
    Monster Cable single Helix 16ga, DHLabs Optical Toslink, DHLabs Prostudio XLR, Peps Power cables all around. Furutech plugs on the Oppo. Kaptain Cables on the TT.
    Speakers;
    SDA1C-boards, caps, resistors, spikes, rings, Dynamat baskets, Rd-0194 tweets.
    RTA11T-caps, resistors, rings, Dynamat baskets, spikes, Rd-0194 tweets.
    5JR- Bone stock all factory original.
    DCM Timewindow-Vifa Tweets.
    Room size and dimensions-16x24x8 feet all calculations for timing and distance handled through the TGP3 all settings on the Oppo zeroed.
    When I received the cables I opened them with my UPS driver watching. We both went ohh and ahh when I unwrapped them. What a spectacular looking cable! Well built and of a no nonsense size. They really command respect from their appearance alone. I set them out for the night contemplating where I would start.
    I began with a CD version of The Cult-She Sells Sanctuary/Live. I have heard this a million times and can even add to the drum solos hehe. I then switched the cables to the Shotguns. The best way to describe it would be the music seemed to move forward towards me as if I had gotten closer to the stage. I also noticed the tweeters picking up detail in the CD that was not previously there. Small minute details, some good some bad, but more detail none the less. I noticed no difference on CD with the changes in impedance if switched at the boxes. I put my originals back in place and grabbed the Vinyl. With The Cars-Heartbeat City I reminded myself why I like dynamics. I then switched to the Shotguns and again I gained a sort of 3 dimensional widening and felt a bit closer to the music. I realized the same differences in the Vinyl that I noticed from the CD. Pops are a bit poppier and the cymbals rang a little longer. The two comparisons proving the same results satisfied my question of whether or not cables make a difference. To me they certainly do. Curiosity getting me now, I decided to actually read the brochures and do it ?Their Way? LOL. Noting these have their best foot forward when used in conjunction with one another I promptly plugged in the first set of IC to the Oppo, fl and r, and to the CD in of the TGP3. I then went to the front current source on the Sig425 and disconnected all of the other XLR cables. Now is when everything should shine it?s brightest, no extra cables or connections and all channels freed no the amp. Unfortunately I didn't notice a discernible difference from the original setup telling me I couldn't completely agree that having nothing in the chain but MIT makes that big of a difference. I even noticed a bit of smoothness with the XLR from the Pre to the Amp that the MIT didn't provide. What I concluded was the speaker cables made the difference not necessarily the IC. I tried every speaker set I own with the same enhancements in detail and dimension. I firmly attribute this difference to the Shotgun S3.3 Speaker Interface Cables.
    There were a couple things that turned me off, first of course is price. If I were to put the sonic differences I noticed in financial terms based on bang for the buck compared to the board and crossover component upgrades done previously I would give the Boards a 10 and the cables a 3.5. Second is the enormous size of the boxes that are said to work the magic. I had a hard time concealing them and frankly I think they are a bit on the gaudy side but if you take away those two negative aspects they are quite a nice set of cables. After this demo am I looking to buy a set of these?? Not really. I like them and they sound good, I can?t take anything from their sound and will certainly hand them some in certain areas, which to me is a good thing, but the boxes are over the top in my view and can say they probably wouldn't stay long if I were to buy a set. The improvements, to me, do not warrant the price and the extra real estate required to house them.
    Thanks again, Jesse, for an awesome opportunity to try out some really great cables. My hat is off to MIT for allowing this traveling audition to take place. I learned quite a bit to further my journey, had a great time and thoroughly enjoyed the MIT Shotgun S3.3 Interconnects and the MIT Shotgun Speaker Interface Cables.
  • Mike Reeter
    Good review 1C, I have to agree with your size comments, they are huge to say the least. The magic boxes on the speaker wires look as if they need their own stands just to support them.
    The MITs are a special cable though, and some things you just have to overlook!
  • brgman
    brgman Posts: 2,859
    Agree.The boxes are a PITA but if that is what it takes so be it.I love my MIT's.
    I’M OFFENDED!!!!
  • SDA1C
    SDA1C Posts: 2,072
    Oh yea. I have nothing but good to say about their sound and after all that IS what it's all about. I had another concern that probably fueled the box size critique and that is if the connections on the speaker are higher than the out side of the box is long. In that case they would need some added support or something to sit on. I am still looking to upgrade obviously and to have the chance to try this big of a jump for next to nothing was a great opportunity. when the kids are gone and the tubes move in I am sure there is something from MIT on the list. But for now...
    P.s. Consider me part of the Blue column lol.
  • Systems
    Systems Posts: 14,872
    Nice review Dan!
    Testing
    Testing
    Testing
    F1nut Posts: 52,406
    What extra real estate? You would still have cable on the floor running to the speakers, these just have a box on them that is a few inches wider than the actual cable. Really, I don't understand the issue. Besides, the boxes say badass like none other....be proud, show them off.
    The speaker cables can be ordered with longer tails. The overall length will be the same, say 8 feet, but the tails will be longer while the main cable will shorter.
    As for needing support, nope. I've had a pair of Shotgun cables "hanging" off the backs of my office speakers for 6 or 7 years, not an issue.
