Amp buzzing and whinning issues
POLKHT
POLKHT Posts: 138
edited November 2012 in Electronics
I'm having issues with my amp. First issue is that when I remove the RCA connections, right after the amp has been on, I get a buzzing noise. Second issue is that when I turn the amp off, a minute or two after, I hear a whinning noise through my speakers.
Anyone know what the issues might be?
Thanks.
Post edited by POLKHT on
    One issue is to never remove the cables with the amp on, you could very well create a short. Hearing a sound after an amp is turned off is usually the caps discharging, most common on older amps. What amp in particular are you talking about ?
  • POLKHT
    POLKHT Posts: 138
    tonyb,
    The amp I have is a Acurus A200x3. I don't think the amp was on when I removed the cables.
