Killing receiver
jparker82
jparker82 Posts: 54
edited November 2012 in Troubleshooting
Quick question, need advice. I seem to keep burning up receivers. I am running Polk LSI 9's LSI25's LSICenter LSIM702 and LSI 7. I have been killing, burning up receivers. Right now I have a Onkyo TX NR 5007 and I am using a Anthem MCA 20 to run the LSI 25's(very power hungry).. I have gone thru a bunch of Integra and Onkyo receivers the last 4/5 years. Any advice.
Should I just switch to processor and Amp? And if so what is best amp to push these 4 ohm speakers?
Onkyo Tx Nr 5007
Integra NAS 2.3 audio serv
Intergra DHS 8.8 HD-DVD
Integra NVS 7.7 Home Theater Media Compt
Anthem MCA 20
Integra 70.1 9 channel amp
OPPO 93 BLU RAY
Monster HDP-2400 power cond
Panamax M5300 PM
Monster HtS-2600 Power cond
Samsung 8000 series e64 plasma
Polk LSI 25
Polk LSI center
Polk LSI 9
Polk LSI 7
Polk LSIM702 fx
Boston Acoustic in ceil #'s ???
Definitive tech sub
Nordost Blue Heaven Rev2 BI wire(great cords)
2 other systems master and pool area
Post edited by jparker82 on
    Need a "fan" over the HDMI boards in all probability. The Onkyos have a problem overheating in that area because of sub-standard parts. They skimped on higher grade items there. You also may be trying to run too many speakers on the AVR. That is possible, especially with 4 ohmers. Though the surrounds and anything less than an LSi-9 should not present a serious problem to the AVR?
    cnh
  • nwohlford
    nwohlford Posts: 700
    The lsi9s and lsic are really no easier to drive than the lsi25. I would get at least a five channel amp to run the lsi25s, lsi9s, and lsic. You can run the remaining four speakers off the receiver if you want. In addition the onkyo receivers ending in 7 and 8 (and the corresponding Integras) have had a number of issues. There are lots of options as far as amps.
    tonyb Posts: 33,072
    Agreed ^^^
    What made you think it was ok to run 4 ohm speakers off an avr anyway ? If you thought the 25's at 4 ohms needed an amp, why wouldn't you amp up the rest of the gang ? Just curious is all, no offense ment.
  • jparker82
    jparker82 Posts: 54
    Every receiver I have bought have been higher end and 6/4 ohms certified. But that seems not to matter. Thanks for the advice. I will probably just drop in a amp. Just sick of spending $$$$. But it's a problem that needs solved. Probably ad another anthem, the one I have now is cold to the touch after hours of running my LSI 25's.
    thanks
    Jason
    Onkyo Tx Nr 5007
    Anthem MCA 20
    OPPO 93 BLU RAY
    Panamax M5300 PM
    Polk LSI 25
    Polk LSI center
    Polk LSI 9
    Polk LSI 7
    Polk LSIM702 fx
    Definitive tech sub
  • jparker82
    jparker82 Posts: 54
    I solved the problem. I added a Integra 70.1 9 channel amp. Thanks for the advice.
    Onkyo Tx Nr 5007
    Anthem MCA 20
    OPPO 93 BLU RAY
    Panamax M5300 PM
    Polk LSI 25
    Polk LSI center
    Polk LSI 9
    Polk LSI 7
    Polk LSIM702 fx
    Definitive tech sub
  • BlueFox
    BlueFox Posts: 15,251
    jparker82 wrote: »
    How do know that this will not also burn up? Is your gear in the open with adequate air flow, or is it enclosed and restricted?
  • Serendipity
    Serendipity Posts: 6,975
    There are three main reasons why a receiver (or amplifier) might fail:
    1. Outputs are low impedance and MUST be connected to high-impedance loads (your speakers). A low impedance load such as a direct short, speaker with voice coil damage, or mismatched load will severly shorten the life of your amplifier. The unit may go into a protection mode forcing the outputs into current-limit, or the unit may even turn off completely. On A/V Receivers, this is usually indicated by a flashing red 'Standby' light. Also, driving a load that is lower impedance than your receiver is rated for is also asking for trouble. The unit may work, but have a shortened life due to the more demanding load.
    2. HEAT - heat is the enemy of any amplifier. Units that are run with components stacked directly on top run the risk of overheating and failing. As the temperature rises, the life of MOSFETs, capacitors, and IC's drops dramatically. A 20'C increase in temperature may shorten the life of some components by as much as 50%!
    3. Voltage on speaker lines - this is very bad. Connecting an amplifier's output to another unit's output, or having voltage present on transmission lines is a surefire way to destroy many amps. So check your connections and make sure the power is OFF before connecting. A unit with its left and right speaker outputs shorted together may likely suffer damage on BOTH channels.
    IMO.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • SugarmillMan
    SugarmillMan Posts: 175
    IMO.
    In my experience, two of my past Onkyo receivers suffered from heat related damage. Both an older Onkyo TX-NR717 and a newer TX-NR 3008 ended up being serviced under Onkyo warranty for heat damaged HDMI boards. Warranty replaced both boards and covered all costs but I had no receiver for many weeks. I always assumed I would be in the clear because I used external amplification and never listened at any loud volume. This was not the case.
    My advice is to purchase a USB powered fan and place on top right rear of the unit. You can look at "the CoolerGuys" and also check out laptop type coolers that are USB powered from many online stores. Any Onkyo or Integra receiver should be monitored for heat problems in my opinion.
    Fronts:B&W 804 Diamonds, Center: B&W HTM2 Diamond, Surrounds: PolkAudio LSi F/X (4)
    Subwoofer: HSU VTK3-MK3
    Electronics: Onkyo TX-NR 3010 receiver, Parasound Halo A31 amp, NAD T975 amp
  • jparker82
    jparker82 Posts: 54
    Thanks for the info on the cooler guys. I do agree every Integra I have ever owned has run hot. Just not as hot as this one. And of course it's wired properly with high quality wires. I never inclose any electronics.
    To answer your ? How do I know problem is solved. The issue of stressing my receiver has been removed. The 70 Integra has a 4 ohm switch and is pushing speakers with no heat.
    I did order 4 sets of fans. Probably overkill but that's Ok. Also upgraded power conditioner.
    Onkyo Tx Nr 5007
    Anthem MCA 20
    OPPO 93 BLU RAY
    Panamax M5300 PM
    Polk LSI 25
    Polk LSI center
    Polk LSI 9
    Polk LSI 7
    Polk LSIM702 fx
    Definitive tech sub
  • SugarmillMan
    jparker82 wrote: »
    If you can post a photo of your set-up after you get the fans, I'm sure everyone would like to see it.
  • halo71
    halo71 Posts: 4,636
    Just curious, when you say you have been through a bunch of receivers. How many exactly is that?
    --Gary--
    tonyb Posts: 33,072
    halo71 wrote: »
    He's got one more to go yet.
  • jparker82
    jparker82 Posts: 54
    tonyb wrote: »
    What does that mean?
    How many. 2 Yamaha one was a z9 other I don't remember the other. On my second Onkyo Txnr 5007. One Integra and a Pioneer Elite. So the short answer is 6. I won't ever buy another receiver. Separates from now on. Funny thing is I don't like my LSI that much.....
    I would be happy to post a pic. I ordered the fans last night on Amazon so it will be a few days.
    Onkyo Tx Nr 5007
    Anthem MCA 20
    OPPO 93 BLU RAY
    Panamax M5300 PM
    Polk LSI 25
    Polk LSI center
    Polk LSI 9
    Polk LSI 7
    Polk LSIM702 fx
    Definitive tech sub
    F1nut Posts: 51,822
    All that does is limit the current.
  • halo71
    halo71 Posts: 4,636
    Wow, you actually burnt up 6 receivers before you decided somethings wrong? Sorry, but damn. I would think after 2 I would be asking some questions.
    --Gary--
  • jparker82
    jparker82 Posts: 54
    halo71 wrote: »
    Nope. Zero of them burnt up. Just lack of original performance. I did not like the sound of the Yamaha receivers so I replaced them. But to be honest I did not realize the strain that the LSI speakers but on electronics. I would never buy them again.
    My equipment gets a massive amount of use. Several battles with my health over the last several years so i have been home alot. We watch tons of movies and the sound is always rocking.
    Onkyo Tx Nr 5007
    Anthem MCA 20
    OPPO 93 BLU RAY
    Panamax M5300 PM
    Polk LSI 25
    Polk LSI center
    Polk LSI 9
    Polk LSI 7
    Polk LSIM702 fx
    Definitive tech sub
  • mdaudioguy
    mdaudioguy Posts: 5,165
    The new LSiM series is 8 ohm - much easier to drive. At Polk, in their HT demo room, they had a complete 7 channel LSiM setup running off a receiver. I still love the LSi series, though. You just gotta feed them properly.
  • halo71
    halo71 Posts: 4,636
    Oh well your first post said "I seem to keep burning up receivers"....that is why I asked.
    --Gary--
  • jparker82
    jparker82 Posts: 54
    Seemed more like trolling than asking..... Just sayin!!!! But my mistake in language.
    Onkyo Tx Nr 5007
    Anthem MCA 20
    OPPO 93 BLU RAY
    Panamax M5300 PM
    Polk LSI 25
    Polk LSI center
    Polk LSI 9
    Polk LSI 7
    Polk LSIM702 fx
    Definitive tech sub
  • codyc1ark
    codyc1ark Posts: 2,539
    jparker82 wrote: »
    I don't feel like he was trolling, rather you did say that you we're 'burning up' receivers. That said, I think you picked up a fine amp. Being a member from 07', you should have known that you couldn't power LSi's from an AVR. I'm interested in your thoughts once you get the amp, remember to re-run your room correction once its dialed in.
    F1nut Posts: 51,822
    jparker82 wrote: »
    Wow, talk about misleading statements and now you say you'll never buy LSi's again. Sounds like you're the troll here.
    Again, you do realize that the 4 ohm switch simply limits current and in doing so compromises the performance.
    tonyb Posts: 33,072
    codyc1ark wrote: »
    Good point Cody, even a review on that Integra amp said it was iffy on anything under 90 efficiency. I'm thinking his problem came in with underpowering and high volume levels which as we all know spells disaster.
  • jparker82
    jparker82 Posts: 54
    I really goes back to bad advice at time of purchase. The GM at sound advice should of pointed out the fact of needing separates at the time of purchase. Think he was more interested in my money. I am very far from a troll. I was simply looking for advice. I stated that I would not buy them again, not because they are bad speakers. Simply because life would be a lot easier with a less power hungry speaker. I would not of continued to add LSI speakers if they where BAD.
    As for me being a member since 07 yes. But I have never claimed to be a techy. I look to this site for advice when needed. I think some assume that everyone should be as tech savy as them. It's just not the case. Funny how people judge from a distance.
    Again thanks for the needed advice.
    Onkyo Tx Nr 5007
    Anthem MCA 20
    OPPO 93 BLU RAY
    Panamax M5300 PM
    Polk LSI 25
    Polk LSI center
    Polk LSI 9
    Polk LSI 7
    Polk LSIM702 fx
    Definitive tech sub
    tonyb Posts: 33,072
    jparker82 wrote: »
    Don't sweat it, it's just from the cheap seats I never knew you had to be a Techy to ask a question. A question we get more times than flies on a cows tail too. Usually sounds like this......."Will my receiver power my LSI speakers ? ". Just saying is all, you could have saved yourself some coinage and agravation.
    As long as your happy in the end I guess is all that matters, enjoy the tunes.
  • jparker82
    jparker82 Posts: 54
    Thanks.
    So am I understanding correctly. The Integra Amp is not a good choice for these speakers. It sounds amazing.
    Onkyo Tx Nr 5007
    Anthem MCA 20
    OPPO 93 BLU RAY
    Panamax M5300 PM
    Polk LSI 25
    Polk LSI center
    Polk LSI 9
    Polk LSI 7
    Polk LSIM702 fx
    Definitive tech sub
  • halo71
    halo71 Posts: 4,636
    See the thing is this....you made mention of turning the volume wide open in an earlier post, burning up more than 1 receiver etc etc. That said, one does not have to be technically inclined here. Please forgive me but it is common sense rather. Turning the volume wide **** open on probably any amp is not a good idea for the amp or the speakers let alone your ears. If the amp starts clipping....that's bad bad bad. And after 1 burnt up receiver "I" would have came here asking questions or even getting my Google on. In a way, one could say they heard the valves rattling in their engine and kept driving then the engine blew up from lack of oil. Most folks would pull over check the oil or whatever right? Bottom line is your receiver ran out of oil and blew up. You should have checked the oil in the second one! :cheesygrin:
    Sorry it that seemed harsh.
    --Gary--
  • jparker82
    jparker82 Posts: 54
    I said rocking not wide open. Hugh diff. I would be deaf. Anyway this thread just needs to die. There must be a delete button somewhere!!!
    Onkyo Tx Nr 5007
    Anthem MCA 20
    OPPO 93 BLU RAY
    Panamax M5300 PM
    Polk LSI 25
    Polk LSI center
    Polk LSI 9
    Polk LSI 7
    Polk LSIM702 fx
    Definitive tech sub
