Advice on Power Cord?
stretchl
stretchl Posts: 1,334
edited October 2012 in Electronics
All -
We're redoing out listening/watching room and I need to get a longer version of the cord that goes to the Panazonic Viera TC-P60S30 TV.
The one that came with the set is about 2 meters, and we probably need double that.
Any ideas on where to look?
Thanks!
- Isaac Asimov
Hi-Fi
Cabling by Groneberg
Visuals
Post edited by stretchl on
  • chumlie
    chumlie Posts: 8,658
    edited October 2012
    Shoot pepster a PM. I'm sure he can hook ya up. He makes quality cables.
    F1nut Posts: 52,301
    edited October 2012
    That's a captive power cord, isn't it?
  • Glowrdr
    Glowrdr Posts: 1,103
    edited October 2012
    Not sure what you mean by captive, but I just had the same issue. I just picked up a 15 footer from Monoprice. The only issue is the "holder" they use on the OEM cord would not work. It fits on the cord, but I guess the part that plugs into the TV isn't as long (assuming you get a 90)
    No issues with the cord falling out, and its on a fully articulating mount
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
    F1nut Posts: 52,301
    edited October 2012
    Captive means hardwired as opposed to an IEC type connection.
  • zingo
    zingo Posts: 11,258
    edited October 2012
    Monoprice will do the job for a good price. I like PS Audio Punch cords, and they can be had used for a good price.
    What style connector does the TV use for the power cord?
  • drumminman
    drumminman Posts: 3,396
    edited October 2012
    My panny plasma has a standard IEC connector, but the TV end is in a sort of tunnel. It's too small for any aftermarker IEC cord I've seen.
  • stretchl
    edited October 2012
    - Isaac Asimov
    Hi-Fi
    Visuals
  • zingo
    zingo Posts: 11,258
    edited October 2012
    What if you got a right angle adapter, then used any power cable?
  • Glowrdr
    edited October 2012
    I actually went with the 14awg version of that (http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10228&cs_id=1022809&p_id=7686&seq=1&format=2)
    Like I mentioned, the part that goes into the TV is long enough, but you won't be able to use the plastic clip to hold in into place. Otherwise Zingo's idea would work fine too - although it would be unecessary since you can just buy a cord that works without adding adaptors.
    Pioneer Elite SC-37
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
  • stretchl
    edited October 2012
    Got it. Thanks.
    I'll just get the 14 also.
    I appreciate everyone's contribution to my edjeekashun.
    :smile:
    - Isaac Asimov
    Hi-Fi
    Visuals
