Advice on Power Cord?
stretchl
All -
We're redoing out listening/watching room and I need to get a longer version of the cord that goes to the Panazonic Viera TC-P60S30 TV.
The one that came with the set is about 2 meters, and we probably need double that.
Any ideas on where to look?
Thanks!
Thanks!
“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Cabling by Groneberg
Visuals
- Isaac Asimov
Hi-Fi
Visuals
Post edited by stretchl on
Shoot pepster a PM. I'm sure he can hook ya up. He makes quality cables.
That's a captive power cord, isn't it?Political Correctness'.........defined
President of Club Polk -
Not sure what you mean by captive, but I just had the same issue. I just picked up a 15 footer from Monoprice. The only issue is the "holder" they use on the OEM cord would not work. It fits on the cord, but I guess the part that plugs into the TV isn't as long (assuming you get a 90)
No issues with the cord falling out, and its on a fully articulating mount65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa" -
Captive means hardwired as opposed to an IEC type connection.Political Correctness'.........defined
Monoprice will do the job for a good price. I like PS Audio Punch cords, and they can be had used for a good price.
What style connector does the TV use for the power cord? -
My panny plasma has a standard IEC connector, but the TV end is in a sort of tunnel. It's too small for any aftermarker IEC cord I've seen."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
Glow, is this the one you have?
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10228&cs_id=1022809&p_id=7678&seq=1&format=1#largeimage
There's a 15' on Amazon but several reviews make it sound dangerous:
http://www.amazon.com/Cables-Go-28593-Meters-Universal/dp/B000ERG5XK/ref=cm_cr_pr_product_top“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
http://Vimeo.com/channels/stretchphoto -
What if you got a right angle adapter, then used any power cable?
I actually went with the 14awg version of that (http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10228&cs_id=1022809&p_id=7686&seq=1&format=2)
Like I mentioned, the part that goes into the TV is long enough, but you won't be able to use the plastic clip to hold in into place. Otherwise Zingo's idea would work fine too - although it would be unecessary since you can just buy a cord that works without adding adaptors.65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Got it. Thanks.
I'll just get the 14 also.
I appreciate everyone's contribution to my edjeekashun.
- Isaac Asimov
Hi-Fi
Visuals
