Denon AVR 1913 Audyssey
oleon621
oleon621 Posts: 178
edited December 2012 in Electronics
I ran the setup and it set my speakers to large. Is that right? I do have a subwoofer. It's a 5.1 channel btw.
Csi5 center
Tsi400s front
Ts 15s in the rear
Psw 505 sub
Front- RTI A7,(powered by ADCOM GFA 5500)
Center- CSI5,
Surrounds- RTI 6 and Rear Surrounds- TS 15.
TV-Panasonic P55ST50
SUB-SVS PB10-NSD and PSW505
Receiver- Yamaha Aventage RX-A2000
Post edited by oleon621 on
    Clipdat Posts: 13,101
    edited October 2012
    Should be set on small, unless the speakers feature a bass driver like a 10" or 12" woofer in them.
    http://www.audyssey.com/blog/2009/05/small-vs-large/
  • nhhiep
    nhhiep Posts: 877
    edited October 2012
    My denon set my Csi5 as Large as well, but before I run audyssey. I manually set it to small and cross at 80hz. Your TSI400 is small too. I set my Rti12 to Large, however.
    edited October 2012
    You can always cross those over higher as mentioned above. I have my M-70s (similar to TSI-500s)/CS2 set at 60hz and that works in my room. You should experiment in the 60-80hz range and see what sounds BEST to you! The surrounds should be set to 80hz (they're small).
    Should sound pretty good with that Denon AVR!
    Enjoy!
    cnh
  • oleon621
    oleon621 Posts: 178
    edited October 2012
    Ok so I should set all my speakers to small and frequency @80hz and then run the Audyssey? Yea my TSI400s don't have any of those big size woofers built in lol. Tempted to buy rti12 though. Once all that is setup I guess ill switch from 80 to 60hz and see what sounds better.
    Thank you all for the replies.
    Center- CSI5,
  • oleon621
    oleon621 Posts: 178
    edited October 2012
    Audyssey set front and center to 40hz and rears to 60. Should I change it to 60-80 or leave it alone? I'm honestly a bit loss/confused.
    Center- CSI5,
    edited October 2012
    Audyssey is NOT a "perfect" system. So you have to trust your ears. Also, the lower you set your crossover on the L/C/R channels, the more you will push your AVR (it does have limited power reserves, better to let the sub handle the very lowest frequencies to take some stress off it).
    I say listen to it at 40hz and also at 60hz. What do your ears tell you, then go with that. I suspect you'll find 60 hz to be a little better?
    Don't let the "automation" get to you. Some of us bypass it entirely and use SPL meters to balance our setup (no need for you to go there at this point).
    Just have some fun!
    cnh
  • oleon621
    oleon621 Posts: 178
    edited October 2012
    Ok cool. Also for my ps3, should I set it to bitstream or linear PCM?
    Center- CSI5,
    edited October 2012
    Your receiver is new enough to be able to decode new HD audio formats via HDMI out/ins so I'd probably go with pure bitstream and let the AVR process this.
    Linear PCM is usually used when you don't have HD Dolby and DTS decoding in your AVR so that you can still pass a 7.1 HD soundtrack and have the AVR play it.
    Just to make sure. Load a Blu-ray with a Dolby HD soundtrack on it and see if the appropriate indicator light lights up on the Denon for Dolby Tru HD when the PS3 is set to bitstream.
    cnh
  • oleon621
    oleon621 Posts: 178
    edited October 2012
    So I set the speakers to 60hz and I like it so far, should I run Audyssey again or leave as is with the manual changes?I also Set the ps3 to bitstream and I see Dolby HD. Everything sounds great!
    Thanks for the help! All of you. I'm loving my system more and more.
    Center- CSI5,
    edited October 2012
    No, don't run the calibration again. Thats the whole purpose of doing a manual adjustment, to suit your ears. As long as your happy, we're happy, rock on.
  • oleon621
    oleon621 Posts: 178
    edited November 2012
    If I want more bass from my sub. Should I do it from my receivers option setting or the knob in the back? I like a little more ooooomph in my movies.
    Thanks :biggrin:
    Center- CSI5,
  • oleon621
    oleon621 Posts: 178
    Would this work with my setup? I'm just curious. Just a novel idea.
    http://reviews.cnet.com/2300-34232_7-10014302-7.html
    Center- CSI5,
  • sponger
    sponger Posts: 325
    oleon621 wrote: »
    Thanks :biggrin:
    If the sub was set up properly from the onset, then the settings on the sub should be permanent. If you want louder bass from the sub, then the sub's output level in the receiver's "channel level" settings would be the option to explore.
    Denon X7200WA
    LSiM 705 703 704c
    Denon DP 400
    Yamaha CDC 775
  • oleon621
    oleon621 Posts: 178
    In the end this how my setup ended up. Fronts and center were manually set to 60hz while surround and surround back were set @80hz. Subwoofer was placed where i felt got the deepest bass. Turned the knob in the back down and ran audyssey until it was a +_0 on the subwoofer setting. This gave me really good results. Really enjoying the setup.
    There are a couple of other things I still need to do. Like matching cable lengths of the front three and using a a better gauge wire(14 instead of 16). Any other suggestions are welcomed!
    Thanks for listening to my rants.
    Center-CSI5
    Fronts- TSI400(itching to upgrade to RTI series soon)
    Rears(4 total)-TS15
    SUB-PSW505
    Denon AVR-1913
    P.S.
    A good friend of mine with $3000+ bose system was really impressed with my setup :cheesygrin:
    Could't believe how well it sounded.
    Center- CSI5,
  • oleon621
    oleon621 Posts: 178
    A quick picture.
    Center- CSI5,
  • jbooker82
    jbooker82 Posts: 1,627
    cnh wrote: »
    cnh
    I might have to mess with mine. I was told to set pcm because it was better to have the player decode. That way the AVR recieves the 5,7,9 channel audio from the player vs having to decode it.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • oleon621
    oleon621 Posts: 178
    jbooker82 wrote: »
    I was just reading this.
    http://reviews.cnet.com/4520-13817_7-6462511-4.html
    Center- CSI5,
  • sponger
    sponger Posts: 325
    I can't say for sure, but I would think that the glass table top has some kind of an impact on the sound from the center channel. Maybe put a section of cloth there or something? I dunno.
    Denon X7200WA
    LSiM 705 703 704c
    Denon DP 400
    Yamaha CDC 775
  • jbooker82
    Good find. So I guess since it doesn't really matter then I might as well try bitstream and see how my onkyo does at decoding.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • oleon621
    oleon621 Posts: 178
    My Denon does a really good job and I'm sure your Onkyo will too.
    Center- CSI5,
  • slider2828
    slider2828 Posts: 118
    I believe Denon and Onkyo is hte same company....
