Solen and Mundorf
deronb1
deronb1 Posts: 5,021
edited November 2012 in DIY, Mods & Tweaks
Just ordered Solen caps and Mundorf resistors from Vr3 to mod my 2Bs. I have never used either product. Anyone have experience with either (both)?
Post edited by deronb1 on
  • Hobbyguy
    Hobbyguy Posts: 317
    edited October 2012
    You will be very happy purchasing from Vr3...so glad I did the upgrade on my LSi9s
  • deronb1
    edited October 2012
    Thanks, good to know. So, you are using Solen and Mundorf on your 9s?
  • Hobbyguy
    Hobbyguy Posts: 317
    edited October 2012
    Mine are clarity....I will leave it up to Trey which are better....there is no question the upgrade is worth it. I am using my LSI9s as my main for HT and the sound is just so realistic to me, much better than before.
    heiney9 Posts: 25,496
    edited October 2012
    Why do people always ask about products AFTER they order them.
    First off, there are atleast 100 posts about this question already
    Second, Solen are better than electrolytics but they aren't the best choice for high pass (tweeter) circuits. Clarity Cap would have been a better choice at that price point. Solens are fine for low pass.
    But that doesn't really matter since you already bought them.
    F1nut Posts: 51,962
    edited October 2012
    Should have gone with Sonicap and Mills. Seriously.
    edited October 2012
    What he said........but that would have been a lot more money.
    At your price point Clarity would have been better than Solen, with Sonicap being the "best" choice without going crazy $$$.
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited October 2012
    Do have a simular question (however i have not purchased yet). Did my 5jr+'s with clairity(SA) caps (and love them) i will start buying caps for my RTA12c's in january. Will go no less than the clairity sa's but figure it will have at least 600.00 in parts by the time i do the risistors and the wire, rdo 198 and gold termimators and 5 way binding posts ect. Just woundering if it is worth looking at sonicaps or better with that budget? And is there an audibal diff by going beyound the clairity SA and what the realstic cost increase might be? As it is i will spread the cost over a couple of checks so i can go at least as far as the clairity.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • deronb1
    edited October 2012
    heiney9 wrote: »
    Well, first of all, I trust Vr3s judgement in recommending caps. Just wanted to know what kind of "change" people have noticed using these caps and resistors. Second, you have no idea what I paid for the transaction. And third? well....let's just keep it civil. Thanks for pointing out the flaws in what is supposed to be a fun activity.
    F1nut Posts: 51,962
    edited October 2012
    RTA12's do not use RD0198-1 tweeters.
  • soundfreak1
    edited October 2012
    The RDO198 cant be upgraded into the 12c's even with a cap change???
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    F1nut Posts: 51,962
    edited October 2012
    He should have never recommended Solens.
    Well you asked, "Anyone have experience with either (both)?" not what kind of change, so we're answering your original question. As for what to expect from a crossover upgrade on 2B's, the forum is full of those threads, including those that suggest not using Solen caps and many more that suggest doing the TL upgrade.
    We all know what those products cost.
    F1nut Posts: 51,962
    edited October 2012
    Simply changing a cap without solid evidence of what the result will be is never a good idea. Has anyone here done this before?
  • soundfreak1
    edited October 2012
    Id sware i read in one of the mod threads this can and has been done. Could be wrong and will double ck before attempting.however how about the other ?'s in my reply.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    F1nut Posts: 51,962
    edited October 2012
    Of course, but rest assured using Clarity SA's will be a major step up from the stock caps.
    Sure, every brand has a different flavor and even with the same brand the flavor changes as you move up or down the line. You can check prices yourself.
    F1nut Posts: 51,962
    edited October 2012
    I looked, but there isn't a schematic listed for the RTA12C's. Looking at the RTA12B's I can tell you it would take more than a single cap change.
    There are crossover modeling programs available that would help point you in the right direction.
  • soundfreak1
    edited October 2012
    I have the rdo 194 in there now but if can i want the 198 just cause! But will put my read on. Just dont know the diff propertys of the sonicaps vs the clarity. If i am going to put that much in the 12c's , dont want them to be lacking over just a few $$ differance.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • deronb1
    edited October 2012
    The "TL" upgrade is stupid expensive. I have the sinking feeling that no one here could tell the difference between a Bennic cap and a Clarity cap when put to the test.
    F1nut Posts: 51,962
    edited October 2012
    You don't know what you're talking about. On your 2B's all that is required is an additional cap and changing the tweeters resulting in a vastly improved speaker.
    You'd be wrong, very wrong.
    I'm not sure why you have an attitude about this. With all due respect to Trey, there are many folks here that have a lot more experience with these things than he does. It would behoove you to listen to them.
  • deronb1
    edited October 2012
    Alright, then it just a matter of opinion. like opinions on sound quality of speakers, I assume the same applies to caps and any other upgrade applications. lets not crazy on our opinions or we will be politicians! :)
    F1nut Posts: 51,962
    edited October 2012
    Upon reflection of your comment above and knowing Trey, I have to think you gave him a budget that Solen fit into because I can't see him recommending them otherwise.
  • deronb1
    edited October 2012
    although no budget was mentioned, i did balk at the TL upgrade quote. The price was less than 80 bucks shipped for the caps and resistors, so if there is ANY improvement is SQ, it will be worth it.
    F1nut Posts: 51,962
    edited October 2012
    Smallies wrote: »
    Ima order me some Mox 1.2
    You'd do better to get that room in order before anything else. If you need suggestions, just ask.
    F1nut Posts: 51,962
    edited October 2012
    All I can say is to that is you get what you pay for.
    Oh, there will be an improvement, just not what it could be, but we all start somewhere.
    F1nut Posts: 51,962
    edited October 2012
    For starters, get a proper rack, stand, table, whatever for you gear. Get whatever piece of gear that is on top of the right speaker off of it. Is that the only wall you can put the speakers on in that room? If so, that sucks, but we'll roll with it. Either get wall to wall carpet or a very large area rug to cover that hardwood floor. Get rid of that video game on the left side, which has to cause horrible reflection issues. Cover those windows with heavy drapes. Spike those speakers.
    What's on the side of the room not in the picture? What size is the room?
    F1nut Posts: 51,962
    edited October 2012
    Yeah ok, just trying to help you achieve better sound, but if you don't care so be it. Just don't offer ANY advice here about sound because you can't with a set up that horrible.
    VR3 Posts: 29,539
    edited October 2012
    I took the liberty to upgrade your tweeter capacitor to Clarity Cap PX at no charge :)
    Will be able to ship your parts mid next week!
    Thanks!
  • gimpod
    gimpod Posts: 1,793
    edited October 2012
    deronb1 wrote: »
    Sorry but I have to call like I see it. I've read some really stupid posts here but this one is right up there with "I can hear the difference in my system when powered by a coal fired power plant or a nuclear power plant".:eek:
    The only way that this statement even comes anywhere close to being true is if your NOT going to be updating the stock SL2000 tweeters. If this is the case my I make a suggestion, Call Vr3 and see if you can cancel your order then sell those SDA 2B's to someone who will make the effort and spend the money to upgrade them the way they should be.
    Keep in mind that as of the last time I checked the RDO-198 cost the same as the RDO-194 (The drop in replacement for the SL2000 and a much better tweeter) around $100 a pair add under $10 for a pair of Solen 5.6uF caps.
    So if you go with the parts you've ordered from Vr3 and get the RDO-194's your looking at around $180 total. if you TL them with the 2 caps and RDO-198's instead of the RDO-194's your looking at around $190 total. How is that "stupid expensive".
    deronb1 wrote: »
    Just like F1nut said "You get what you pay for" as far as "ANY improvement is SQ" go's if your keep the stock tweeters there will be some but I wouldn't expect much.
    F1nut Posts: 51,962
    edited October 2012
    Smallies wrote: »
    I care but I'm not going to saws-all and remove the stairs which is really what I need. How is a big heavy amp atop a speaker hurting anything, wouldn't it stabilize it a bit? I also love that cold air intake that it's sitting on is that my fault? sissy
    Yeah, your room lay out sucks, but it could be made better with a little effort. I offered you solid proven advice, if you choose not to take it's your loss.
    I've said it before and I'll say it again, there's something not right with you. Do you take medication?
    F1nut Posts: 51,962
    edited October 2012
    VR3 wrote: »
    Very nice!
