DENON AVR 2113 OR 2313 with Polk Rti 7
john1970
Hi
I am looking to buy the POLK Rti 7. I have short listed Denon avr 2113 & 2313. Which one of these would you suggest ?
Post edited by john1970 on
I'm not a fan of Denon anymore and think you could do much better with something else. But if your heart is set then I suggest saving a few more pennies and getting the AVR3313. It has more power then the 2313 which your RTIA7's will like. They are a good speaker that sound and perform better with more current.
If I had to choose between those 2 , I would go with the 2313. Why? Dual sub outs on the 23 which can come in handy when using 2 subs , More power in 10 watts more per channel. I really think the 2113 is way underpowered to run a nice speaker like the RTia7's.Dan
I personally love my denon i have a 3312 and there is almost no difference in performance between the 3311 3312 and 3313 if yoou dont have to have the latest and greatest a slightly used reciever can be picked up for a great price and can be a great performer.... like around 600 or less.Harman kardon signature 2.1 amp
Denon 3312
Epson 8700ub
Chief mount
Screen Innovations Performance Series 110in
Kef q 500 (RL)
Kef q 200 (C)
Kef q 800 (Rear RL)
REL T7 (SUB)
mx 450 remote
Sonos-Amp, Connect, Play5 -
How about an OK receiver with preouts and a good amp?HT: M5510-Prox2/PN51E550/NR708/M282(3)/RTi A7/CSi A6/FXi A6/DSWPro660x2/PS3/HTPC
Office: Belkin PF60/PN43E450/Marantz 1501/PSB 400/Image C4/WD Live TV
2-Channel: Yamaha C4/M4(2)/DQ-10's/DQ-1w(2)/SBT/Pioneer R2Rl/Technics SL-7/AR EB101
Desk: QSC RMX850/Behringer B2030P -
Not a bad Idea but there are plenty of good quality receivers that will bring out the RTIA7's. A used SC model from Pioneer Elite will make those babies sing.How about an OK receiver with preouts and a good amp?Dan
