Need a couple of recommendations
jwl
Hello,
I have the following equipment on order.
Polk PSW10 Subwoofer
Polk Monitor 40 Series II bookshelf speakers
HT Omega eClaro (http://www.htomega.com/eclaro.html)
How would you recommend I connect them and what cables would you recommend (and where should I buy them)?
Thanks,
J
Thanks,
J
Post edited by jwl on
I think you need to be a little more specific here - "How would you recommend I connect them.."
already covered in a different thread.Polk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2 -
From my personal experience cabling matters but not as much as anyone says it does. Find yourself a decent set of monster cables or similar quality product on Amazon.com or somewhere online. Gold plated tips are nice but I am not convinced they are necessary. If you buy them online you will save a few bucks and get the same thing. NEVER buy used or old cables. The insides and the ends can corrode and that will degrade quality.
