Need a couple of recommendations
jwl
jwl Posts: 53
Hello,
I have the following equipment on order.
Polk PSW10 Subwoofer
Polk Monitor 40 Series II bookshelf speakers
HT Omega eClaro (http://www.htomega.com/eclaro.html)
How would you recommend I connect them and what cables would you recommend (and where should I buy them)?
Thanks,
J
Post edited by jwl on
  • jtapoling
    jtapoling Posts: 3
    edited October 2012
    I think you need to be a little more specific here - "How would you recommend I connect them.."
  • 11tsteve
    11tsteve Posts: 1,166
    edited October 2012
    already covered in a different thread.
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
  • jtapoling
    jtapoling Posts: 3
    edited October 2012
    From my personal experience cabling matters but not as much as anyone says it does. Find yourself a decent set of monster cables or similar quality product on Amazon.com or somewhere online. Gold plated tips are nice but I am not convinced they are necessary. If you buy them online you will save a few bucks and get the same thing. NEVER buy used or old cables. The insides and the ends can corrode and that will degrade quality.
