rear centre
Willow
Willow Posts: 11,371
edited May 2004 in Speakers
Do most peeps use a dedicated centre for the rear centre or a "left over" book shelf ?? and how do I set this up if the couch is against the wall ???
  • PolkWannabie
    PolkWannabie Posts: 2,763
    edited May 2004
    IMHO you move the couch or you use bi/dipoles back there and the latter might be preferable even if you don't move the couch.
  • gatemplin
    gatemplin Posts: 1,595
    edited May 2004
    I use a CSi30 but a leftover bookshelf will work also. My couch is also up against a wall so I made a shelf and put the speaker up about 6.5' off the ground, it works fine.
    Others in this situation have tried putting the rear center behind the couch firing up.
    Graham
  • Willow
    edited May 2004
    thanks any good shops in TO Im there saturday day and night
  • gatemplin
    edited May 2004
    The main ones I know of are Bay Bloor Radio, Kromer, Brack, and Audio One.
    Graham
  • Willow
    edited May 2004
    thanks Ill tell my wife there lots of great shopping there and excuse myself.....thanks !!
  • gregure
    gregure Posts: 871
    edited May 2004
    For the amount of input a back center channel actually gets (not too much), it would be wise just to use a left over bookshelf, rather than spending the money on a dedicated center. That back center is just an added f/x speaker, with not nearly the amount of sound output to justify spending more money on a center speaker. Even with DTS ES 6.1. In my opinion, of course.
    Current System:
    CSi5-Center (for sale**)
    FXi3-surrounds (for sale**)
    Martin Logan Depth-Sub
    B&K AVR 507
    Pimare CD21-CD Player
    Denon 1815-DVD Player
    Panamax M5500-EX-Line Conditioner
