'Warm' meaning????
snake1
Ok, been looking and reading amp threads for ........I don't know how long. Well apparently, with my 12s, a 'warm' amp is preferred..........what does 'warm' mean???
The amps that have been suggested for 12s and A9s is usually parasound, bk, etc. and these are the warm ones?? Is this crushingly important or just suggested and really any quality amp will help?? Forgive all the questions, learning in progress!
AVR - Onkyo NR809
500gb HD for MP3 and FLAC files
Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
Mains - Polk RTi12 towers
Center - CSi5
Surround - FXiA6's
Sub - psw505
Movies and games - PS3
TV - Toshiba 52" HD
Every vehicle has one good nuetral drop in it
Center - CSi5
Surround - FXiA6's
Sub - psw505
TV - Toshiba 52" HD
Post edited by snake1 on
The best way I can describe it is it's more laid back, especially on the upper end of the spectrum. The Rti12's can be very forward sounding speakers (i have a pair) because they were designed that way for home theater use. Some consider them bright, especially for music. A "warm" amplifier will help tame the treble down, without reducing the detail.
Warm meaning not bright,in your face,brash,harsh,shrill on the highs! Meaning smooth,mellow,With easy reserve power. Thats how i feel about warm!
I'm sure someone else will chime in,with how wrong or right I am."Everything I ever did in my life worthwhile I caught hell for" -
Let me ask another question. Does the AVR have anything to do with this issue? Can turning down the treble help compensate if a 'warm' amp can't be afforded??AVR - Onkyo NR809
Center - CSi5
Surround - FXiA6's
Sub - psw505
TV - Toshiba 52" HD
Every vehicle has one good nuetral drop in it -
I like to avoid any kind of adjustments as far as bass or treble, I don't like the idea of adding or taking anything away from the music. However with that said you can tame the treble a little bit without it being an issue. Not 100% but I think with Audyssey you don't have the ability to adjust the eq or tone controls, it's either on or off.
With it set i have changed the bass and treble levels in the past.AVR - Onkyo NR809
Center - CSi5
Surround - FXiA6's
Sub - psw505
TV - Toshiba 52" HD
Ok, I guess it was my older Denon that I had to turn Audyssey off before I could use the tone controls. I think any of those brands of amps will pair nicely with that avr and you'll have a great system going. Keep in mind speaker cables and interconnect cables can effect the sound as well, i'd personally save a little $ for some decent ones.
Well i can't do much in this area.... Price es are too hi even used. Naturally emotivas have caught my eye but they have mixed reviews...AVR - Onkyo NR809
Center - CSi5
Surround - FXiA6's
Sub - psw505
TV - Toshiba 52" HD
They tend to be a brighter sound amp as well, they have very mixed reviews on here. I'd just keep an eye on craigslist, i've seen some great deals between 300-500ish that would do the job. Be patient and do some research and you'll find what you're looking for.
I can go in and adjust the treble and bass but I cannot adjust the EQ unless I go in and manually set it up. I cannot tweek Audyssey's tone / eq adjustments. That is on my Onkyo TX-NR808AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
I always copied the Audessy EQ settings into the custom EQ and made changes from there.
FWIW in my limited experience warm sounding speakers/amps have a more laid back sound to me with a deeper sound stage that seems to spread more evenly between the two speakers. Bright sounding speakers/amps seem very in your face, like the music is being hurled at you from the speakers and present a shallower, more two dimensional sound stage.
The A9's for example were very in your face to begin with. The addition of the Parasound with some audessy tweaking smoothed and relaxed the sound, warming it up and making it easy to listen to them for hours without fatigue.Up
LSi15 LSiC - RX-V3000
Down
Sim2 D60 - Dragonfly 106" Panny 500
