Speaker Dampening RTIA's
tommyt21
tommyt21 Posts: 685
edited October 2012 in Speakers
I am going to rebuild the Crossovers in my RTI A6 & A7's using the Fortress kit from Trey. While I have everything opened up would it be worth using some type of dampening material inside the RTI cabs? If so what would be a good choice and what kind of performance can I expect?
Living Room
Fronts: RTi A7's
Center: Csi A6 VR3 "Fortress Plus"
Front Heights: Rti A1
Surrounds: Rti A3
Sub: HSU VTF-2 MK4 Damn this is a good SUB
Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
TV: Lg LW6500 55" Passive 3D
Blu-Ray Panasonic BD 210
XboX 360 Slim/Kinect
Acoustimac red suede panels
  • zingo
    zingo Posts: 11,258
    edited October 2012
    Many have tried cabinet dampening including myself, and results are mixed. Done wrong it will decrease your sound quality, done well it will give a small improvement to those speakers. If you do it, do it for a fun project and to possibly increase sound quality; don't do it to bring big sound quality changes or add value.
  • jbooker82
    jbooker82 Posts: 1,627
    edited October 2012
    I dynomated my drivers in my CSI and RTi's while I was waiting on trey's mods.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
    F1nut Posts: 52,368
    edited October 2012
    Did you notice a difference?
  • jbooker82
    edited October 2012
    For the dynomat specificaly I cant say that I do. I just noticed when you knocked on the magnet shields with your knuckes they rang. So I though it wouldnt hurt. I was bored while waiting for my XO's to get back from trey so I though what the heck, it only cost 20 bucks for the dynomat.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • gce
    gce Posts: 2,158
    edited October 2012
    jbooker82 wrote: »
    There's a better way to stop that...don't knock on your mangnet shields with your knuckes! :razz: Sorry, couldn't help myself. LOL
    I saw your mod when I was having mine done but decided not to do it. Thanks for noting you didn't notice a difference, puts my mind at ease.
    Anaheim Hills CA,
    HT 5.1: Denon X3900H/ BDP-Denon DBT1713UD / Polkaudio LSiM703 / W4S mAmp's / Polkaudio LSiM706c / Polkaudio LSiM702F/X's / SVS SB2000 Pro / Panasonic TC P55VT30
  • jbooker82
    edited October 2012
    Well it is kind of one of those deals where the only time they might ring is when the drivers are pounding prett hard. So now are you going to be able to hear the ringing over a pair of RTi's that are screaming loud?
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    F1nut Posts: 52,368
    edited October 2012
    jbooker82 wrote: »
    For the [Dynamat] specificaly I cant say that I do. I just noticed when you knocked on the magnet shields with your knuckes they rang. So I though it wouldnt hurt. I was bored while waiting for my XO's to get back from trey so I though what the heck, it only cost 20 bucks for the [Dynamat].
    You're right, it doesn't hurt. Any stamped steel basket will ring, so applying Dynamat Extreme is always an excellent idea. IIRC, I started that tweak a long time ago on my SDA's. I definitely noticed an increase in mid-range clarity.
  • tommyt21
    tommyt21 Posts: 685
    edited October 2012
    It looks like I may skip doing it. I'll have enough to do this week when the DIY kit comes in from Trey. Its the Fortress "+" Edition. HeHeHe... More on that later this week.
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
    F1nut Posts: 52,368
    edited October 2012
    Might as well do it while they are open.
  • jbooker82
    edited October 2012
    I had the xo's modded at the same time so I really cant say how much each modd helped. I just figured that the xo's was the bigest part of it.
    The other thing I can see with dynomating the drives is that it adds mass. There for when the driver cones are slamming back and fourth the extra weight on the basket and magnet shields acts as ballst to help minimize vibrations wich would cut out unwanted sounds, or improve clarity.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    F1nut Posts: 52,368
    edited October 2012
    No doubt, the crossover upgrade is going to net greater results.
    You're spot on about what adding Dynamat Extreme does.
