Amp wiring and hookup
snake1
snake1 Posts: 567
edited October 2012 in Electronics
Been looking at amplifiers lately. I've been curious about hookup. Using the preouts to the amplifier it looks like you can use plain RCA cables. 'Plain' may not be the proper term. I found some cables on monoprice for subwoofers but wondering if it would work for amp cables as well.
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10236&cs_id=1023603&p_id=2681&seq=1&format=2
Thoughts?? Also, do you keep these cables a short as possible for clean install reasons? I'm looking to just a get a 5 channel at some point.
AVR - Onkyo NR809
500gb HD for MP3 and FLAC files
Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
Mains - Polk RTi12 towers
Center - CSi5
Surround - FXiA6's
Sub - psw505
Movies and games - PS3
TV - Toshiba 52" HD
Every vehicle has one good nuetral drop in it
Post edited by snake1 on
  • zane77
    zane77 Posts: 1,696
    edited October 2012
    Subwoofer audio cables will work, "plain" cables will also work although there is a benefit to going with better interconnects, short as possible is best and keeping the interconnects and the speaker cables away from the power cables will also help. If they have to cross it is best at 90 degrees to keep as much noise as possible out of the speaker and interconnect cables. Also keeping all the cables as short as possible keeps it from looking like a rat's nest of cable behind everything. Good luck with your hunt.
    Two Channel
  • snake1
    snake1 Posts: 567
    edited October 2012
    Thanks for the info zane!
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
