Crossover frequency
SebastianG
SebastianG Posts: 14
edited October 2012 in Speakers
need help with my Crossover frequency for my Rm85 speakers Right now my front is 120hz center is 120hz and my sorround is 150hz im using a STR-DH710
  • goofyGAguy
    goofyGAguy Posts: 545
    edited October 2012
    What are you needing help with? Are you using a sub? All speakers set to "small"? If so, those numbers look about right to me.
    My humble setup...
    ...is no more. :cry:
  • oleon621
    oleon621 Posts: 178
    edited October 2012
    If I have 2 TsI 400s and a csi5 for center with a pair of rear random speakers. What frequency should I be using . I have no sub at the moment.
    Front- RTI A7,(powered by ADCOM GFA 5500)
    Center- CSI5,
    Surrounds- RTI 6 and Rear Surrounds- TS 15.
    TV-Panasonic P55ST50
    SUB-SVS PB10-NSD and PSW505
    Receiver- Yamaha Aventage RX-A2000
  • goofyGAguy
    edited October 2012
    If you're not running a sub, the question of crossover frequency is kind of moot, no? :confused:
    My humble setup...
  • oleon621
    oleon621 Posts: 178
    edited October 2012
    I'm a real noob at all this. The last time I purchased surround sound system it came in a box and just plugged and play, haha. I'm going to guess it doesn't matter right? However, my Denon Receiver ask what frequency i would like my center and front channel speakers at. Any idea why?
    Center- CSI5,
    edited October 2012
    Turn your speaker settings to large instead of small, and make sure you set the subwoofer to "no" or none. You don't have to worry about crossovers untill you add a subwoofer.
  • badchad
    badchad Posts: 348
    edited October 2012
    oleon621 wrote: »
    Maybe your AVR "thinks" you have a subwoofer in your setup? Have you gone through the options and set it up so you DON'T have sub?
    Polk Fronts: RTi A7's
    Polk Center: CSi A6
    Polk Surrounds: FXi A6's
    Polk Rear Surround: RTi4
    Sub: HSU VTF-3 (MK1)
    AVR: Yamaha RX-A2010
    B&K Reference 200.7
    TV: Sharp LC-70LE847U
    Oppo BDP-103
  • oleon621
    oleon621 Posts: 178
    edited October 2012
    I do have it set to no subwoofer. I guess I"ll be ok until I purchase a sub. Thanks guys!
    Center- CSI5,
    edited October 2012
    If you have them set to small with no sub, your missing out on alot. Make sure you set them to large to get the full frequency range.
  • oleon621
    oleon621 Posts: 178
    edited October 2012
    I have them set to large. So I guess I'm ok for the moment. Thanks.
    Center- CSI5,
  • Thorton
    Thorton Posts: 1,324
    edited October 2012
    oleon621 wrote: »
    Did you run the auto calibration? And as others have said, without the sub, set the speakers to large.
    _____________________________________________________________________________________
    AVR: Denon AVR-3805, AMP: Parasound Model 2250, Front: Polk RTIA7, Center: Polk CSIA6, Surrounds: Polk FXIA6, Sub: Polk DSW PRO660WI
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • oleon621
    oleon621 Posts: 178
    edited October 2012
    Unfortunately my receiver doesn't have that option. I have Entry level Denon AVR1513. I do have them set to large though.
    Center- CSI5,
