Crossover frequency
SebastianG
need help with my Crossover frequency for my Rm85 speakers Right now my front is 120hz center is 120hz and my sorround is 150hz im using a STR-DH710
What are you needing help with? Are you using a sub? All speakers set to "small"? If so, those numbers look about right to me.My humble setup...
...is no more.
If I have 2 TsI 400s and a csi5 for center with a pair of rear random speakers. What frequency should I be using . I have no sub at the moment.Front- RTI A7,(powered by ADCOM GFA 5500)
Center- CSI5,
Surrounds- RTI 6 and Rear Surrounds- TS 15.
TV-Panasonic P55ST50
SUB-SVS PB10-NSD and PSW505
Receiver- Yamaha Aventage RX-A2000 -
If you're not running a sub, the question of crossover frequency is kind of moot, no?
My humble setup...
...is no more.
I'm a real noob at all this. The last time I purchased surround sound system it came in a box and just plugged and play, haha. I'm going to guess it doesn't matter right? However, my Denon Receiver ask what frequency i would like my center and front channel speakers at. Any idea why?Front- RTI A7,(powered by ADCOM GFA 5500)
Center- CSI5,
Turn your speaker settings to large instead of small, and make sure you set the subwoofer to "no" or none. You don't have to worry about crossovers untill you add a subwoofer.HT SYSTEM-
lsi 9's -
Maybe your AVR "thinks" you have a subwoofer in your setup? Have you gone through the options and set it up so you DON'T have sub?Polk Fronts: RTi A7's
Polk Center: CSi A6
Polk Surrounds: FXi A6's
Polk Rear Surround: RTi4
Sub: HSU VTF-3 (MK1)
AVR: Yamaha RX-A2010
B&K Reference 200.7
TV: Sharp LC-70LE847U
Oppo BDP-103 -
I do have it set to no subwoofer. I guess I"ll be ok until I purchase a sub. Thanks guys!Front- RTI A7,(powered by ADCOM GFA 5500)
Center- CSI5,
If you have them set to small with no sub, your missing out on alot. Make sure you set them to large to get the full frequency range.HT SYSTEM-
lsi 9's -
I have them set to large. So I guess I'm ok for the moment. Thanks.Front- RTI A7,(powered by ADCOM GFA 5500)
Center- CSI5,
Did you run the auto calibration? And as others have said, without the sub, set the speakers to large.I have them set to large. So I guess I'm ok for the moment. Thanks.
_____________________________________________________________________________________
AVR: Denon AVR-3805, AMP: Parasound Model 2250, Front: Polk RTIA7, Center: Polk CSIA6, Surrounds: Polk FXIA6, Sub: Polk DSW PRO660WI_____________________________________________________________________________________________
DAC: Bricasti M1SE
Pre/Pro: Marantz AV8805
Subs: 2 - Rythmik F25's
Room Treatments: GIK Acoustics -
Unfortunately my receiver doesn't have that option. I have Entry level Denon AVR1513. I do have them set to large though.Front- RTI A7,(powered by ADCOM GFA 5500)
Center- CSI5,
