hanging rt55i on wall
vteconly
vteconly Posts: 2
Hi everyone, i have two sets of rt55i that i would like to hang on the wall as main and presence speakers. I've looked at some mounting hardware options; but while they do work well, they are not very attractive. So what i am thinking of doing is making a box out of plywood big enough to slip these rt55i's into and then secure these boxes onto the wall with lag screws. This way, i can paint the boxes or stain if i wish .
My question is, will putting the rt55's into another box degrade the sound quality? these are ported speakers so that is the reason for my concern. Please advise.
Hank.
Post edited by vteconly on
    tonyb Posts: 33,072
    edited October 2012
    Short answer is yes. Build a shelf, but not a box. Pretty big speakers to put on a wall, no ?
    Toolfan66 Posts: 18,071
    edited October 2012
    Not a speaker I would put on a wall..
  • rooftop59
    rooftop59 Posts: 8,121
    edited October 2012
    Yep I agree with Tony except I raise you one! Put those mains on stands unless it is really not an option. get some good steel stands, fill em with sand and shot, and you will hear those babies in all their glory. if you build a shelf, even a well built one, those speakers will be vibrating a lot which lets out a lot of air and noise that's supposed to be coming out of the speaker and port only. Solid stands make this happen the way it should. The first time I put some bookies on good stands I was blown away by the difference, for me the tighter bass was the most obvious.
    Presence speakers are probably fine even in a box as not much bass or sound that's a focal point will come out of them, but the mains need to be on a good, solid foundation.
    good Luck!
    Game Room 5.1.4:
    Bedroom 2.1
  • shawn474
    shawn474 Posts: 3,052
    edited October 2012
    I use the btech 77 mounts for my rt55's. they have been up and working great for a few years. They are like these mounts: http://www.amazon.com/Rocelco-B-Tech-BT77-Ultragrip-Loudspeaker/dp/B004DCAOHK
    Shawn
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
  • thsmith
    thsmith Posts: 6,082
    edited October 2012
    I just picked up a pair of 55s and could not imagine hanging those beast. They do look great on stands though.
    edited October 2012
    I have said it many times but damn I hate the fact that I sold mine. They were mint I had them since new from circuit city original boxes and all..
  • mantis
    mantis Posts: 17,433
    edited October 2012
    Don't hang them on the wall , they are not designed for wall mounting. They are to big anyway. I suggest getting a pair of in wall speakers for Presence duty and use the other pair on stands as mains.
    If you can find a pair of RT35's or Rt25's , they are wall mountable VIA key hole slot on the power port.
    Dan
  • DrkHwk
    DrkHwk Posts: 20
    edited October 2012
    I considered trying to hang my 55's. Got some nice stands, definately the way to go IMO
  • cconklin1
    cconklin1 Posts: 10
    edited October 2012
    awful big for a wall..
  • How do I get the speaker grill installed in the rc55i?
    VR3 Posts: 29,442
    The rc55 is an in wall product.
    The metal grill pushes into the baffle around the perimeter
