Looking for advice on speaker stands
steveinaz
steveinaz Posts: 19,547
edited May 2004 in Speakers
Once I get my Athena's sold, I'll be getting a set of Lsi9's. I don't want to go crazy here, whats the best bang for the buck in a good set of stands for the Lsi 9? What are some good brands to look at?
  • gacole2000
    gacole2000 Posts: 255
    edited May 2004
    Steve,
    You may want to check out this thread.
    http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=18514&highlight=speaker+stands
    Further, I saw your plot on your new SVS. I need to do that with mine. If it is not too much trouble, would you mind sending me what you used please. I would really appreciate it.
    Thanks- Greg
    gregory_cole@hotmail.com
    AVR: Yamaha RX-V661
    DVD: Yamaha DV-C6480
    BR: Samsung 1600
    Mains: Polk RT55 (bi-amped)
    Center: CS300
    Sides: FX1000
    Rears: RT/FX
    Subs: SVS 20-39 PC+ 12.3 & DIY SVS 12.2
    Projector: Optoma HD70 w/ 106" Elite Screen
    Power: Panamax MAX 5100
    Remote: Harmony One
  • pjdami
    pjdami Posts: 1,894
    edited May 2004
    Kind of pricey, but these look nice if you like the thick look to them:
    http://www.audioadvisor.com/store/productdetail.asp?sku=SOUZ522
    The bottom of the LSi 9 (the ebony part) is exactly 7 inches wide and over 13 inches deep. I prefer the top plate to be as large as possibly to minimize chances of tipping the speaker over.
    Audio Advisor has a large selection of speaker stands. Some eBay searches may help. I lucked out and got some nice stands used from my local hifi shop.
    Paul
  • tryrrthg
    tryrrthg Posts: 1,896
    edited May 2004
    If you've got the tools I would HIGHLY suggest building your own. I built some based off the TNT-Audio Stubby design. It was a pretty easy and fun project. The beauty of DIY is you can make them look however you want. You can make the top plate the exact same size as your speakers. You can paint them any color you want, and make them as tall as you want. If you go with MDF for the wood you could probably make them for less than $50 and they'll probably easily weigh over 50 pounds when filled with sand. My stands are much more stable than any stand that I have seen for less than $150. The only stands that I've found that would come close to DIY stands in value are the stands from Parts Express but they have a very large top plate. And one more thing, don't forget to get Blu-Tack. it will keep your speakers from falling off the stands, and does a great job of damping and keeps your speakers safe!
    Some pics of my DIY Stands
    Construction pics
    PE Stands
  • HBombToo
    HBombToo Posts: 5,256
    edited May 2004
    Perfect timing on this thread since I'm also looking for stands... I really like the Parts express jobbies but am open for any suggestions.
    HBomb
    ***WAREMTAE***
  • steveinaz
    edited May 2004
    tryrrthg thanks, I've looked thru your website before on those stands...very nice.
  • tryrrthg
    edited May 2004
    No problem. Thanks for the compliment. If I didn't go DIY I probably would have gone with the ones that pjdami posted, but those didn't pass the WAF, and my DIY ones did.
    Good luck with your search!
  • PolkWannabie
    PolkWannabie Posts: 2,763
    edited May 2004
    Steve,
    I'd like to understand your thought process ...
    Your selling you Athena's because you state you won't have room in your new house ... but ...
    Your wanting the LSi9's to be on stands, assumedly floor stands ...
    How does this setup not take as much floor space as the Athena's ?
    Did I miss ? or incorrectly state something here ?
    Rick
  • steveinaz
    edited May 2004
    The stands will be temporary until we ge into the new house , which will probably be a year from now. i still have to either come up with an interesting solution for getting the speakers off the ground, or talk the wife into a different entertainment center--which i don't want to do, the one we have is very nice, and she gives into my "audio wishes" 99.5% of the time, so she's gonna get her way on this one.
    The problem is, the new familyroom has about 4' less floor space because of a corner fireplace; I can't get the entertainment center, 2 floorstanders and a sub into that space, so I'm thinking of building shelves off of the sides of the entertainment center to raise the Lsi9's off the floor enough to clear the SVS, but yet not be too high to where fidelity is compromised.
    You guys have any ideas/suggestions? All help is welcomed!
    Envision this, draw a line 10" long (1"=1FT). Now, at the right end of that line, draw a line 45degrees for 4" (this is the fireplace). The 10" line represebts the wall I have to play with to get a 7.5FT entertainment center, and a 16" diameter SVS sub into. So, somehow, someway, I've got to get the Lsi's off the floor..HELP
  • PolkWannabie
    edited May 2004
    Ah ... I got it now ...
    However with 10' of room - 7.5' of entertainment center = 2.5' of speaker space or 1.25' per or 15".
    Is there no chance the sub can go elsewhere i.e. a back corner ? If your X/O is fairly low I wouldn't think you'd notice.
  • steveinaz
    edited May 2004
    It's a strange room, only 2 walls (open space floorplan) but I'm gonna look at the display house again and see if I can't find another location for the subwoofer.
