monitor 70 or polk rti a3 for rears
jmrskyhigh
Hi need help i have polk rti a7 fronts CSI A6 center polk monitor 70 for rears an polk monitor 30 for sides. should i upgrade the rears an side to polk rti a3
Welcome to Club Polk!
Frankly, I wouldn't bother to do that unless you need the space. You won't notice much of a difference and the M-70s have a far greater range than A3s in any case!
Only your front three really need to be matched.
You're good! Cosmetically, of course, the system would look nicer with a matched set of A series speakers, though!
Ditto to what cnh said. Unless the non-matching set really really really bothers you, I wouldn't spend the money.Living Room:
Paradigm Cinema 330 x 3, Pioneer 9040TXH
Media Room:
RTi12, CSi5, F/Xi3, RTi4, Onkyo SR805, SVS PB12 Plus/2, HSU MBM -
I would get a pair of FXI A4's or 6's for the sides, then move the monitor 30's to the rear. Then sell or use the M70's in a different system.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
I agree with the first two, keep what you've got but move the 70's to sides and the 30's to rear.
Actually, bookers idea is a pretty good one.Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB9000-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-11.2 -
thanks for the help . why move the 70s to the sides
same as cnhMarantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
B&K ST.3140 Power Amplifier
HSU Research VTF2 MK3
Vizio P65-C1
Panasonic 605 blu ray
Onkyo DS-A4 i-pod Dock
Universal Remote
BDI Icon 9429 TV Stand -
jmrskyhigh wrote: »thanks for the help . why move the 70s to the sides
More content goes through the sides than the rearsMarantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB9000-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-11.2 -
Thanks again moved 70 to the side they sound better
