monitor 70 or polk rti a3 for rears
jmrskyhigh
jmrskyhigh Posts: 3
edited October 2012 in Speakers
Hi need help i have polk rti a7 fronts CSI A6 center polk monitor 70 for rears an polk monitor 30 for sides. should i upgrade the rears an side to polk rti a3
    edited September 2012
    Welcome to Club Polk!
    Frankly, I wouldn't bother to do that unless you need the space. You won't notice much of a difference and the M-70s have a far greater range than A3s in any case!
    Only your front three really need to be matched.
    You're good! Cosmetically, of course, the system would look nicer with a matched set of A series speakers, though!
    cnh
  • vadang
    vadang Posts: 101
    Ditto to what cnh said. Unless the non-matching set really really really bothers you, I wouldn't spend the money.
    Living Room:
    Paradigm Cinema 330 x 3, Pioneer 9040TXH
    Media Room:
    RTi12, CSi5, F/Xi3, RTi4, Onkyo SR805, SVS PB12 Plus/2, HSU MBM
  • jbooker82
    jbooker82 Posts: 1,627
    I would get a pair of FXI A4's or 6's for the sides, then move the monitor 30's to the rear. Then sell or use the M70's in a different system.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • Geoff4rfc
    Geoff4rfc Posts: 3,043
    I agree with the first two, keep what you've got but move the 70's to sides and the 30's to rear.
    Actually, bookers idea is a pretty good one.
  • jmrskyhigh
    jmrskyhigh Posts: 3
    thanks for the help . why move the 70s to the sides
  • over50
    over50 Posts: 201
    same as cnh
    Marantz SR 7007
    polkaudio RTi10
    polkaudio CSi A6
    polkaudio RTiA3
    B&K ST.3140 Power Amplifier
    HSU Research VTF2 MK3
    Vizio P65-C1
    Panasonic 605 blu ray
    Onkyo DS-A4 i-pod Dock
    Universal Remote
    BDI Icon 9429 TV Stand
  • Geoff4rfc
    jmrskyhigh wrote: »
    More content goes through the sides than the rears
  • jmrskyhigh
    jmrskyhigh Posts: 3
    edited October 2012
    Thanks again moved 70 to the side they sound better
