Studies On Residential Power Line Noise - Part 1
13»
  • bilbeau
    edited August 2008
    Nope ya cant convince me that you can hear the difference between a 10.00 cord and a 100 dollar cord. Aint no way no how!!!!
    Your ears can deceive you. Sometimes we hear what we hope to hear.
    Like I said show me what the scope shows on the outputs of the power supply. Show me the outputs with a regular cord then with a high dollar cord.
    I cant go by someones hearing. One day you can hear up to 20KHz next day only to 19.9KHz
    I have worked around B52 aircraft repairing avionics systems for years so my hearing is not what it once was so tell me why would I hear any difference.
    I'm not doubting the findings of the input power. After twenty plus years of being in the electronics field I have seen plenty of dirty AC power. I just cant see how 6 feet of wire is going to clean that up.
    http://www.billbeau.net
    Carver
    Twin M400 Power Amps
    Pioneer
    SA-9500II RT-909
    TX-8500II CT-F1000
    SG-9800 PL-518
    RG-1 PL-540
    PDR-609
    SAE
    5000
    5000A
    DBX
    224
    228
    400X
    400XG
    Infinity
    Qe 2-way Speaker
  • DarqueKnight
    edited August 2008
    It will be difficult finding someone on this forum who is brave enough to go poking around inside an energized power amp with an oscilloscope. Most, if not all, of the guys around here who had those kinds of balls went over to the Audioholics forum (www.audioholics.com).
    Good luck with your research.
  • reeltrouble1
    edited August 2008
    hopefully the recommendation will not fly so high as to be missed.
    RT1
  • ben62670
    edited August 2008
    bilbeau wrote: »
    Just a curiosity question. Why do you think he is trying to convince you that you can hear a difference? I don't really think he cares if you can hear a difference. He doesn't sell any of the products he has mentioned. He like other hear love the hobby, and he (I think) is looking for ways to measure scientifically what he hears. It's his trade.
    DK please correct me if I am wrong.
    Ben
    Ben
  • DarqueKnight
    edited August 2008
    bilbeau wrote: »
    OK...but please be advised that no "convincing" was attempted.
    bilbeau wrote: »
    I agree...and that deception can be a very good thing. Every time I listen to my SDA's, my ears deceive me into believing that sound is coming from in front of, above, behind, to the sides of and in between the speakers. Sometimes, if the recording quality is really, really good, my ears deceive me into thinking that there are real three dimensional people in the room making the music, rather than two wooden boxes, some assorted wire, and electronics.
    bilbeau wrote: »
    Actually, I go into a cable or component evaluation with negative bias. The more expensive the cost of the cable or component, the higher the negative bias. I hope (wish) that I don't hear an improvement, or that the improvement will be so small that the cost to upgrade will not be justified. I would prefer to keep money in my pocket.;)
    bilbeau wrote: »
    I did show the differences in oscilloscope measurements at the outputs of my amplifiers when power cords were switched in part 2 of this series. We can then infer that there must be differences at the output of the power supply inside the amp, therefore, I don't think it is necessary to go poking around inside my amps. However, I'm sure there are other meter pontiffs who would relish that sort of inquiry. Finding one shouldn't be too difficult...if you know where to look.
    bilbeau wrote: »
    Nor should you. Kudos.
    bilbeau wrote: »
    One day you can hear up to 20KHz next day only to 19.9KHz.
    I have not read any scientific studies on the day to day variances in human hearing sensitivity, but would enjoy learning about it. Can you point me to some literature on the subject?
    bilbeau wrote: »
    I have worked around B52 aircraft repairing avionics systems for years so my hearing is not what it once was...
    That can be a blessing and a curse. Thanks for the insight into your personal frame of reference.
    bilbeau wrote: »
    ...so tell me why would I hear any difference.
    :confused:
    bilbeau wrote: »
    Some things are difficult to understand.
    ben62670 wrote: »
    I wondered about that myself.
    ben62670 wrote: »
    You are correct, sir.
    ben62670 wrote: »
    Correct again. I would also like to add that I would prefer it if I could achieve my home audio and video goals with the fine products sold at Walmart. No luck so far.:(*
    *wink.gifBut he's patient.
  • pinecone
    edited September 2012
    DarqueKnight,
    I am just getting started with audio measurements and really enjoy your posts.
    I am trying to replicate some of your measurements so I can learn and was wondering what probe you are using and how you have it hooked up to the 2012?
    Thanks for your time, I appreciate your help.
  • DarqueKnight
    pinecone wrote: »
    Tektronix P2220 probe connected to channel 2 of the oscilloscope. I use channel 2 because of the red trace color compared to the yellow color on channel 1. Red photographs better.
    When taking voltage measurements from the wall or end of a power cord, don't connect the ground lead of the oscilloscope probe as you would with a multimeter.
    The probe tips are too short to fit into the Line side socket of a wall plate or power cord. To take these types of measurements, I inserted a multimeter probe into the wall or cord and used the probe's hook clip attachment to connect to the other end of the multimeter probe cord.
    Enjoy.
    Man DK, all this talk of photograghs, probes, clips, tips.....your turning me on. LOL !!
  • wkjeffers
    3rd harmonics are common for ac to dc conversion. ie. electronics.
  • wkjeffers
    also not e that CFL bulbs and LED bulbs contain ballasts that create huge amounts of harmonics. Power quality studies project that if a factory were to convert to all CFL bulbs, there DC drives might not work correctly because of all the harmonics. Also I have seen LEd bulbs completely wipe out an FM station signal due to the RF interference.
  • oldmodman
    Giant isolation transformer.
    I live very close to TRW and they have a monthly electronic & ham radio swap meet in their parking lot. And I bought a two hundred pound "scientific" isolation transformer from the TRW surplus department.
