Carver MXR-150
tophatjohnny
tophatjohnny Posts: 4,189
edited September 2012 in Electronics
Would this be a good receiver to drive the SDA-2B's??
Post edited by tophatjohnny on
  • onebadchad
    onebadchad Posts: 364
    I believe that particular Carver amp is common ground, but you should check because many carvers are not. It is not a good amp for running less than 8 ohms though, and the SDA 2b's run less than 8 ohms, would not be my first choice. I think you could find something much more suitable that is more stable at lower ohms. Good Luck
    Hello Kitty am/fm CD player
  • zingo
    zingo Posts: 11,258
    Without hearing it, I would say it would do a decent job.
    http://www.carveraudio.com/index.php/receivers/mxr-150
  • tophatjohnny
    After looking closer at it, it looks more like band gear, so switching to possibly get the HK AVR 635 (I think that's the model) and call it a wrap for the bedroom.
  • SDA1C
    SDA1C Posts: 2,072
    Never seen band gear receiver....I have the 900 which is in the same family. It does a super job with my sda. I would double check the common ground and rock out. Guaranteed its sounds better then the HK
    Too much **** to list....
  • SDA1C
    SDA1C Posts: 2,072
    onebadchad wrote: »
    says it good for 4 or 8....
  • tophatjohnny
    SDA1C wrote: »
    What I meant by band gear, is the handles. Reminded me of band days?? The seller of the Carver is offering it up to me for 50.00 delivered to my door,(he only lives a mile from me:lol:) so a hundred less than the HK, I may have to chomp on that tonight a little?? Especially if you say the Carver will sound better?? That is what matters. Besides the handles on the Carver, the thing looks brand new.
  • onebadchad
    Thats a steal. Buy it for trading material
    EndersShadow Posts: 17,751
    My AV-705x Carver 5 channel amp had rack handles too, I would jump on that piece if I was you :smile:
    For a 50.....it's worth it, but I wouldn't expect my musical experience to expand by leaps and bounds.
  • George Grand
    George Grand Posts: 12,256
    I drove less than 4 ohms with one of those Carver 150's for about two years. Amp never hiccuped or got even close to hot.
    Lot of people just talk to get heard.
