Connectors.......
May consider anything unused.
I am looking for some GLS (non-locking, just the basic) rca plugs in particular.
A/C plugs, rca plugs, XLR, nanners/spades, I'm game.
Watcha got?
If you have some "Used" connectors I might be interested also, just pm me.
  • brgman
    brgman Posts: 2,859
    edited September 2012
    I have some nanners i think
    maybe rca's i need to look
    i have some sweet vampire rca's but the guy i gave them to for cables disappeared on me
    I’M OFFENDED!!!!
  • Systems
    Systems Posts: 14,872
    brgman wrote: »
    THAT JERKOFF!
    Any idea who it was?
    Same guy that offered to buy all those Vamps laying around here :)?
    Testing
    Testing
    Testing
  • brgman
    brgman Posts: 2,859
    Never got any offers from the jackarse for them either.
    The key question here is-Do connectors really matter?
    I’M OFFENDED!!!!
  • Systems
    Statement #1: I think we have both established your memory is about as long as a Skittle!
    Question #2: No comment :).
    Testing
    Testing
    Testing
  • Face
    Face Posts: 14,340
    brgman wrote: »
    Yes.
  • brgman
    brgman Posts: 2,859
    Face wrote: »
    Yes.
    So is a $10 connector is 5 times better than a $2 connector?
    I’M OFFENDED!!!!
  • Systems
    Can you PROVE that Face?
    JK!
    I learned long ago the "no comment" works better for my particular situation.
    But I would certainly have to admit, after hearing a pair or two myself, you may be on
    to something there :)!
    Testing
    Testing
    Testing
  • Face
    Face Posts: 14,340
    brgman wrote: »
    There's no direct correlation, IMO. What's more important is the base material. Large mass connectors such as RCAs and binding posts, it's important to use a copper base under gold coating, as brass sounds poor in comparison. IMO, small mass connectors such as XLR and speakon, it's less important.
  • Systems
    Problem is Face, you could probably count on 1 hand the amount of "copper" rca's on the market today.
    As far as base material goes.
    Keep in mind and make note, there are alot of "copper center pins" on the market (brass base for the return).
    And some of those are KILLER (Onix comes to mind).
    Nothing really wrong with brass, not the best naturally.
    Been a mainstay for 25 years and some of the best cables on the market use brass, but they are designed,
    and materials selected for that alloy connector.
    If I were to build a cable, I would build it around the connector.
    And believe me, that is NOT why I was asking about the GLS connectors, LOL!
    I am a Cardas rca man myself, knowing how each sounds and designing accordingly.
    Testing
    Testing
    Testing
  • headrott
    headrott Posts: 5,496
    I've got a pair of brand new Switchcraft male XLR chassis mount sockets. I was going to use them on my DAC, but ended up going with the much more expensive (but better) Furutech XLR jacks for the DAC. PM me if you need these. Thanks.
    Greg
