Acurus 125x5 (Anyone have one, or heard one??)
tophatjohnny
Just checking. I have one on the way to check out, and not having heard of the brand, the owner of the amp spoke highly of it. Said I may have to leave this one on for a couple of weeks to really hear it at it's best?? I comes out of a home theater set up that was said to be used only a handful of times, and needs to broken in?? Never heard of that either?? I'll have it tomorrow, and am concerned the 125 watts wont be much more kick than my HK Pa5800?? Any comments on that are also welcome. Thanks
Post edited by tophatjohnny on
Acurus is a very good choice. You should enjoy it for sure."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Okay, no Acurus owners on the air today........I'll tell all, as tomorrow one will be delivered and set up. Wish me luck!!"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
LOL, reading almost any review with the name Acurus in it should most likely calm your nerves. If subjectively, it doesn't work out getting rid of it should be very easy.tophatjohnny wrote: »Okay, no Acurus owners on the air today........I'll tell all, as tomorrow one will be delivered and set up. Wish me luck!! -
from what I heard, Acurus has the same or better reputation than HK. between the Acurus 125x5 and pa5800, I will take a Acurus.
CRESCENDOPOWER wrote: »LOL, reading almost any review with the name Acurus in it should most likely calm your nerves. If subjectively, it doesn't work out getting rid of it should be very easy.from what I heard, Acurus has the same or better reputation than HK. between the Acurus 125x5 and pa5800, I will take a Acurus.
Thanks guys, and can't wait to hoop this baby up and let her go. I mean...turn her up...I mean let the thing Rip....okay, can't wait to see if my old ears can tell a difference!!
Man can I tell a difference......Night and Day!!
The HK is sweet, but I have to say, the Acurus is a big step up from that. Yeah..these old ears still work!! "if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
Sounds good. Actually there are a number of people here who run a 2 or 3 channel, not 5 channel Acurus amp and every one of them has given their amps positive reviews. Now we can add you to that list. NO surprise there!
Enjoy!
