Speakers upgrade from RM2300 to TL3
SebastianSF
SebastianSF Posts: 2
edited September 2012 in Speakers
Hi,
I am upgrading my Home Theater system. I used to ave Denon AVR-1905 and Polk Audio 2300 and 2600 Center speaker. I had it for 9 years and was very happy with it. When I moved I gave it to a friend.
I just ordered Denon AVR-1612. The living room is 16X12 and I don't have room for floor speakers and can't install bookshelf speakers. I am looking at ordering Polk audio blackstone TL3 and TL3 center speakers. My uqestions is:
How does Polk audio TL3 compare to RM series?
Is it compaitable with Denon 1612? Are there any issues with it?
If not what would you recommend?
Sebastian
  • jkg123
    jkg123 Posts: 114
    What type of components are you hooking up to the receiver?
  • MADGSF
    MADGSF Posts: 603
    I have nver heard the RM series speakers but I am using TL3 for a desk top system. For music I prefer them over my RTi10s and find the sound to detailed but smooth. Similar to the LSiM series speakers, you will love the TL3 but make sure you have a good sub to go with them.
    AVR: Elite VSX-21TXH
    Amplifier: B&K 7250 Series ii
    Misc: Velodyne SMS-1
    Mains: RTi-10
    Center: CSi-5
    Rear: Boston DSi460
    Sub: SVS PC-Ultra
    TV: Panasonic TC-P58V10
    DVD: Panasonic DMP-BD60K
  • SebastianSF
    Thank You! I live in an apartment so can't use Sub,of floor speakers or Bookshelf speakers for that matter (neighbors on both side). Just need decent front speakers that I can mount on stands and a center channel.
