Speakers upgrade from RM2300 to TL3
SebastianSF
Hi,
I am upgrading my Home Theater system. I used to ave Denon AVR-1905 and Polk Audio 2300 and 2600 Center speaker. I had it for 9 years and was very happy with it. When I moved I gave it to a friend.
I just ordered Denon AVR-1612. The living room is 16X12 and I don't have room for floor speakers and can't install bookshelf speakers. I am looking at ordering Polk audio blackstone TL3 and TL3 center speakers. My uqestions is:
How does Polk audio TL3 compare to RM series?
Is it compaitable with Denon 1612? Are there any issues with it?
If not what would you recommend?
Sebastian
Sebastian
Post edited by SebastianSF on
What type of components are you hooking up to the receiver?
I have nver heard the RM series speakers but I am using TL3 for a desk top system. For music I prefer them over my RTi10s and find the sound to detailed but smooth. Similar to the LSiM series speakers, you will love the TL3 but make sure you have a good sub to go with them.AVR: Elite VSX-21TXH
Amplifier: B&K 7250 Series ii
Misc: Velodyne SMS-1
Mains: RTi-10
Center: CSi-5
Rear: Boston DSi460
Sub: SVS PC-Ultra
TV: Panasonic TC-P58V10
DVD: Panasonic DMP-BD60K -
Thank You! I live in an apartment so can't use Sub,of floor speakers or Bookshelf speakers for that matter (neighbors on both side). Just need decent front speakers that I can mount on stands and a center channel.
