? about wire maintence
leftwinger57
leftwinger57 Posts: 2,917
edited August 2012 in Electronics
I was wondering if coiling of ICs or speaker wire is a good idea. I do it for aesthetics but really do not know if it's the right thing to do. Yes 1pair of ICs are measured and bought from Signal Cable but there are others at varying lengths so to clean it up a bit I do coil and then either ty-rap or tape. I know the general rule is the shorter the better both when buying boutique or off the shelf both for price and performance.This is a little confusing only because most all wires are either jacketed or even sheilded..
  • pearsall001
    pearsall001 Posts: 5,384
    edited August 2012
    I wouldn't lose any sleep over it.
  • decal
    decal Posts: 3,205
    edited August 2012
    The sky is falling, the sky is falling !!!!!
    heiney9 Posts: 25,630
    edited August 2012
    I wouldn't loose sleep over it, but if you can aviod it (especially with speaker cable) then do so. But if you like the aesthetics then I wouldn't be too worried unless you are talking about coiling 25'+, then there might start to be an issue.
    You also should have signal carrying cables perpendicular to power cables and power cables should never run parallel on top of each other, etc, etc. Just try and be mindful of those ideas if you can, but don't loose any sleep over it.
  • RickTfromAZ
    RickTfromAZ Posts: 122
    edited August 2012
    Coiled up wiring will create an increased magnetic field. I have tried it both ways (coiled and uncoiled) with my IC's, Speaker Cables and also power cords. I can't hear any difference. But, this is my system. Yours may behave differently. Experiment.
  • gdb
    gdb Posts: 6,012
    edited August 2012
    We made an electric motor in elementary school with................coils of wire. Be careful that your speakers don't get tipped over, when things start to spinin' !!!!! :wink:
  • leftwinger57
    edited August 2012
    Decal, bl-w me...lol.lol.lol
  • leftwinger57
    edited August 2012
    ME losing sleep ,no Ambien takes care of that ,but I do know you should never run high voltage or ac plug wires next to or bundled w/ your speaker or source cables.my concern was only w/ ICs and some extra speaker wire. were not talking miles here.
  • Glowrdr
    Glowrdr Posts: 1,103
    edited August 2012
    I ran my surrounds under some trim, so it's semi-permanant - I left about 10 feet extra just in case I ever needed to move them a little, or strip an end off for nanners.
    I'd say if you don't realize there is a problem, it more than likely doesn't exist. Now if your speakers hum so loud it shakes the house - then you've got problems.
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
