Definitive Technology SM55 bookshelf speakers
Loud & Clear
Loud & Clear Posts: 1,538
edited August 2012 in Speakers
Used a $350 promotional gift card from newegg to help purchase the $600 DefTech SM55s this evening. Reviews seem positive and I have the feeling these will produce quality sound. Anyone heard them? I believe we're talking about a two-way sealed design with a 6x10 passive radiator on top.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie
Post edited by Loud & Clear on
  • deronb1
    deronb1 Posts: 5,021
    edited August 2012
    I have the SM450 which is the previous version. I think you will like them very much. I love mine for HT, which is what I bought them for. The new series MAY be even better musically. You got a great price!
  • mantis
    mantis Posts: 17,424
    edited August 2012
    I have , they are wonderful. Powerful bass and clear. I think your going to dig them and be a little surprised by their performance.
    Dan
  • Loud & Clear
    edited August 2012
    Thanks for the responses. If I like them a great deal I may replace my wharfedale diamond theater setup with them. Potential problem seems to be an option for a center channel. I don't see a corresponding center for the SM bookshelf models.
    Two Channel Setup:
    DAC: Arcam irDac
    Source: iMac
  • Matt34
    Matt34 Posts: 318
    edited August 2012
    Joe @ Deftec said either use of the SM65 as a center or the CS-8040HD would be good choices. The SM55 is on my list to audition as well.
    Nice to hear you guys like them so far.
  • Loud & Clear
    edited August 2012
    Good info. The CS-8040HD is probably the way I would go if it comes to that.
    Two Channel Setup:
    DAC: Arcam irDac
    Source: iMac
