Which speaker can I add to my 5.1 Polk setup?
Hi all, looking for some speaker help :-)
I currently have a 5.1 home theater setup with a CS2 center, Monitor 50's for the fronts and Monitor 40's at the rear. I want to add the other 2 speakers to make it a 7.1 setup so I can have surround above the 1st row of seats as these do not get a good hit from the Monitor 40's which are working great for the 2nd (rear) set of seating. I was thinking of just putting a pair of Monitor 40's above the seating facing down but they are a little big to hang in that space, so was looking at the in-ceiling speakers. This is just a budget system right now and I am not ready to upgrade all the speakers just yet, so from a compatibility stand point is there any issues adding the RC60i's in-ceiling to what I already have? Or should I go fo somthing else??
Many thanks!!
Many thanks!!
Thanks for the input, any reason you recommend the Monitor 30 and is that recommendation as in don't use the in-ceiling (RC60i) for other reasons, thanks for any help!
