Which speaker can I add to my 5.1 Polk setup?
Hi all, looking for some speaker help :-)
I currently have a 5.1 home theater setup with a CS2 center, Monitor 50's for the fronts and Monitor 40's at the rear. I want to add the other 2 speakers to make it a 7.1 setup so I can have surround above the 1st row of seats as these do not get a good hit from the Monitor 40's which are working great for the 2nd (rear) set of seating. I was thinking of just putting a pair of Monitor 40's above the seating facing down but they are a little big to hang in that space, so was looking at the in-ceiling speakers. This is just a budget system right now and I am not ready to upgrade all the speakers just yet, so from a compatibility stand point is there any issues adding the RC60i's in-ceiling to what I already have? Or should I go fo somthing else??
Many thanks!!
Many thanks!!
Post edited by barrettuk on
Thanks for the input, any reason you recommend the Monitor 30 and is that recommendation as in don't use the in-ceiling (RC60i) for other reasons, thanks for any help!
