smoked my new tweeter
podizzle
Hi guys unfortunately while trying to figure out why my rca was making noise i manages to set fire to my mm6501 tweeter before i had a chance to hear it sing. Is there any way i can order a single replacement?
Post edited by podizzle on
Hello,
You should be able to replace that through Polk's CS department, providing you purchased it from an authorized dealer. Either send them an email at polkcs@polkaudio.com or via telephone at 1-800-377-7655.
Regards, Ken -
i dont believe it was an authorized dealer. im just wondering if its possible to purchase a single tweeter or even a set of mm tweeters?
You can buy what ever you want if you look deep enough, I think that goes without saying. I would, however, avoid letting H9 hear of this oversight as he might be humping your leg for the next 6 months about your abuse of equipment.Too much **** to list....
Hello,
Yes, the same contact information will put you in touch with the CS department and you can order a new tweeter.
Cheers, Ken -
Thanks ken. yes i should have known better than to turn up the gain but the noise sounded like a pure sine wave which is why i thought i was safe. I think the fact i was pushing close to 200w didn't help either
Hello,
When you call Polk select extension 208 and explain what happened to Kim, tell him you joined Club Polk and that I asked you to call. I'm sure he will be helpful.
Cheers, Ken -
As much as I don't mind smoking, I don't recommending smoking any tweeters...
Good luck with the fix. -
Is this really needed in a polk cs question? This part of the forum should be treated like a store front.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
that is true lol
Eh, you're probably right. To be honest I didn't notice the post count, just caught the thread out of the corner of my eye.Too much **** to list.... -
Get rid of the RCA and you'll probably stop frying tweeters.
