Need driver model number
crajos
I picked up set of RT3000P's, and one of the 6 1/2" drivers is either blown or stuck. I was wondering if anybody knew the model driver Polk put in these, or one that will work well with the system. I plan on scavenging eBay for a replacement if I can't free the magnet.
Post edited by crajos on
Take it out and look on the back amd it should say the # on a tag on the magMain Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Oh BTW welcome to the clubMain Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Thanks! Found somebody on here with a replacement driver, so I should be good to go. Polk's are slick speakers. I'm a convert.
Did you pull the driver? Make sure of the # as polk had a habit of changing drivers in the middle of production runs, serioualy check it before you buy the wrong one. nuff said!Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
