Need driver model number
crajos
crajos Posts: 11
edited August 2012 in Troubleshooting
I picked up set of RT3000P's, and one of the 6 1/2" drivers is either blown or stuck. I was wondering if anybody knew the model driver Polk put in these, or one that will work well with the system. I plan on scavenging eBay for a replacement if I can't free the magnet.
Post edited by crajos on
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited August 2012
    Take it out and look on the back amd it should say the # on a tag on the mag
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • soundfreak1
    edited August 2012
    Oh BTW welcome to the club
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • crajos
    crajos Posts: 11
    edited August 2012
    Thanks! Found somebody on here with a replacement driver, so I should be good to go. Polk's are slick speakers. I'm a convert.
  • soundfreak1
    edited August 2012
    Did you pull the driver? Make sure of the # as polk had a habit of changing drivers in the middle of production runs, serioualy check it before you buy the wrong one. nuff said!
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
