Hum anthem pre2l
Hendrik
Hendrik Posts: 13
edited August 2012 in Troubleshooting
Lot of hum!
I have an anthem pre2l with ? lot of hum even when THE volume is to zero
Does anyone know an modification for this problem
Post edited by Hendrik on
  • dpowell
    dpowell Posts: 3,081
    edited July 2012
    It may be one of your tubes going bad.
  • Hendrik
    Hendrik Posts: 13
    edited July 2012
    No its not the tubes, it seems that the this is an problem of the preamp
    The hum is to load, exchange tubes for several other models does not help
  • dpowell
    edited July 2012
    Maybe a cap going bad?
  • dorokusai
    dorokusai Posts: 25,576
    edited July 2012
    Sounds like a transformer ground lifting and failing....I'm presuming you checked all your usual suspects and that's more than a tube. Email Chris @ Parts Connection(x) and see how far he's willing to float some advice since he helped design that unit.
  • Hendrik
    Hendrik Posts: 13
    edited August 2012
    They cannot help me they say it's normal
